Sponsored by: Auxito
U Joints?
Old Jan 4, 2011 | 02:27 PM
seadooxp's Avatar
seadooxp
U Joints?
Vehicle: 2000 Ford F150 Supercab 4X4 4.6L V8 77K
Problem: When I start backing up in my truck I hear a "pop" or "loud bang" come from somewhere in the mid to rear of the truck, does anyone know what this could be or maybe is it a universal joint somewhere? Any help would be appreciated.
Old Jan 4, 2011 | 04:04 PM
seadooxp's Avatar
seadooxp
I hear it when I have already traveled like 5 or 10 feet already.
Old Jan 4, 2011 | 06:56 PM
Dave G.'s Avatar
Dave G.
Rear brake shoes popping loose ? ( if you have drum brakes). Some issues with certain linings sticking to the drums.
Dave
Old Jan 4, 2011 | 09:43 PM
seadooxp's Avatar
seadooxp
Good suggestion I will look!
Old Jan 5, 2011 | 04:05 PM
seadooxp's Avatar
seadooxp
No it's disc brakes in the rear, doesn't seem to be the issue.
Old Jan 5, 2011 | 04:49 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
possible that its u joints, or you could have something damaged in the rear end. I have been through a couple 8.8 rear ends.
Also could be the slip yoke. They can dry up and cause a poping noise. Applying proper grease to the splines takes care of it usually.
Id check u joints first. There are two of them on the drive shaft.
Block your wheels.
Climb under your truck and see if you can see any movement in the u joints when you push on the driveshaft on the ends. There should be no play at all. Absolutly zero movement. and dont be afraid to push on it hard, it can take some force to get them to move sometimes, if they are bound up. I usually put it in neutral to check them.
Old Jan 5, 2011 | 05:15 PM
Dave G.'s Avatar
Dave G.
OK, since it's not the brakes, ditto on the above. Usually, when the u-joints are bad enough to cause that much of a knock when you put it in gear and go one way or the other, there is quite a bit of metal missing internally. You should see the equivalent of metal filings around the u-joint's cups. The filings used to be your needle bearings.
Dave
Old Jan 10, 2011 | 03:16 PM
seadooxp's Avatar
seadooxp
I just pulled out the rear driveshaft to do the u joint job and ATF came out of the high end (where it goes into tranny), is this normal?
Old Jan 10, 2011 | 05:08 PM
Dave G.'s Avatar
Dave G.
Unfortunately, yes. Sometimes, a rag tightly packed in there will slow or stop it, sometimes you can buy a plastic slide in plug just for this.
Dave
Old Jan 10, 2011 | 05:23 PM
seadooxp's Avatar
seadooxp
Thanks for getting back to me quickly Dave, I was a nervous wreck wondering if I messed something up.
Steve
Old Jan 10, 2011 | 09:34 PM
seadooxp's Avatar
seadooxp
Put New U-Joint in closest to the rear axle and didn't hear or feel anything when backing up, we'll see how it is after driving it for a few days. The u-joint closest to the transmission seemed good.
Old Jan 10, 2011 | 10:51 PM
swillett's Avatar
swillett
fords often make crazy backup noises when the u joints are on the way out. it was the first sympton that led me to do mine.
Old Jan 14, 2011 | 04:22 PM
seadooxp's Avatar
seadooxp
All fixed, the hardware on the parking brake failed and was dragging inside of the rear right disc brake. Very happy man now.
sammie0126
Nov 29, 2012 03:50 PM
xltblt
Oct 26, 2011 07:23 PM
bronkntrukholik
Jul 3, 2010 09:25 PM
bullyt
Offroad & 4x4
Nov 17, 2007 06:25 PM
FordPickup460
Dec 13, 2004 06:02 AM
