5.0 performance tips
Old Jan 8, 2011 | 03:58 PM
  #61
zxwut?'s Avatar
zxwut?
Originally Posted by Old93junk
If bottom end power is the most important thing to you, 4.10s or lower, will help your 302.
Otherwise, consider upgrading to a 351w...........a easy swap.
This also would help a lot.
Old Jan 8, 2011 | 04:03 PM
  #62
BET F150's Avatar
BET F150
that is the answer i was lookin for and thank you lew and i dont want a supercharege or a 351
Old Jan 8, 2011 | 07:55 PM
  #63
lew52's Avatar
lew52
Your welcome , and i think the 302 will serve you well , the aftermarket support for them is very good , so you can do just about anything you want with them....Lew
Old Jan 8, 2011 | 08:59 PM
  #64
BET F150's Avatar
BET F150
there like the best motor ever made and the only people that say differnt are chev fans and they thing the 350 is the best
Old Jan 8, 2011 | 09:52 PM
  #65
zxwut?'s Avatar
zxwut?
I do not believe the 302 or the 350 are the "best" engine ever made. Where does that put my crowd?
Old Jan 8, 2011 | 11:17 PM
  #66
BET F150's Avatar
BET F150
well maybe not the best but best for its class and bein domestic do you know what i mean?
Old Jan 8, 2011 | 11:31 PM
  #67
Old93junk's Avatar
Old93junk
I cant buy, "just" the 302.........How about the entire SBF family, 260, 289, 302, 351w!
Old Jan 8, 2011 | 11:33 PM
  #68
xxshine's Avatar
xxshine
Want more power ? Get an ignition curve box. Simple electronic component you control from the cab. Those things work.
Old Jan 9, 2011 | 07:52 AM
  #69
73FOMO's Avatar
73FOMO
It would be great to know a budget as I understood this initial post to be what can I do to get a little more performance from my 5.0. You have got to be a little more specific as it is easy to throw out specs on a killer engine build, but if doesn't fit your budget and it's out of reach then it does no good. I don't know the specs of the 351 cam, but I stand by my earlier post calling for some 1.7 rockers and Comp xe258 cam. You have headers, and this would help the intake side a bit so you're motor breathes a little better. Also try out the search function, I would guess you would find 5 billion threads on this very subject with more information than you could absorb. Guaranteed.
Old Jan 9, 2011 | 12:56 PM
  #70
Conanski's Avatar
Conanski
Yeah the term "351 cam" is meaningless mainly because most of these truck motors use the same cam. A '93 5.0 could certainly use a cam upgrade but the 35-510-8(XE256HR-12) isn't the best candidate(too much lift.. matching valve springs manditory), I suggest the 35-512-8(XE258HR-14) instead since it can be used with the stock springs. Another alternative is an F4TE truck cam from a '94+ 5.0 or 5.8 and add 1.7 rockers to that.
Old Jan 9, 2011 | 05:00 PM
  #71
BET F150's Avatar
BET F150
so the cam from a 351 is the same as the one in my truck? i thought the 351 had a different fireing order?
Old Jan 10, 2011 | 01:35 PM
  #72
TexasGuy001's Avatar
TexasGuy001
X2 for this.
Old Jan 10, 2011 | 07:44 PM
  #73
BET F150's Avatar
BET F150
how much of a change as that like in speed?
Old Jan 10, 2011 | 11:04 PM
  #74
zxwut?'s Avatar
zxwut?
23.4mph for sure. Add a few stickers to the truck also, I hear that helps.
Old Jan 11, 2011 | 07:26 PM
  #75
BET F150's Avatar
BET F150
yea i heard each sticker gives you an extra 5hp hahahaha
krewat
Ford In-Vehicle Tech
Aug 4, 2015 11:51 AM
73FOMO
Oct 10, 2011 07:46 PM
turbill
Dec 22, 2010 06:59 PM
drewk
6.4L Power Stroke Diesel
Mar 12, 2007 09:33 PM
Yeti
Garage & Workshop
Jun 19, 2002 02:44 PM
