Power window engine extraction
Old Jan 3, 2011 | 07:34 PM
Encho's Avatar
Encho
The Southernmost Mod
Exclamation Power window engine extraction
Please check out this link if you think you can help me:
https://www.ford-trucks.com/forums/1...xtraction.html
Old Jan 3, 2011 | 07:43 PM
Volvo92906's Avatar
Volvo92906
I know youre being humorous, no problem. Plus, FTE is here to help. But, its a window regulator, or window motor. Not quite an engine...
Anyhow, its pretty straight forward. If you can pull a door panel off and remove some rivets you can do it.
Old Jan 3, 2011 | 07:52 PM
Encho's Avatar
Encho
Thanks for the correction and the info, in my language both terms are similar so i got a little confused there, about the motor, what you state confirms what i'm thinking, it will be a piece of cake, i just wanted to be sure before i tried anything.
Old Jan 4, 2011 | 05:11 AM
TexasGuy001's Avatar
TexasGuy001
This is definitely not that hard to do at all.
Old Jan 4, 2011 | 07:15 AM
LCAM-01XA's Avatar
LCAM-01XA
that's the hard and messy way, there is another trick to it that makes the job real easy.
Old Jan 5, 2011 | 12:39 AM
TexasGuy001
Whats the other way your thinking of?
Old Jan 5, 2011 | 01:27 AM
LCAM-01XA's Avatar
LCAM-01XA
The way I use every single time I have to do this particular job, this way:
https://www.ford-trucks.com/forums/1...ml#post9773018
Old Jan 5, 2011 | 01:47 AM
TexasGuy001
I don't know what I was thinking. Thats how I do it as well. I guess I was thinking about the power door lock actuator.
1990_Tan_F250
Jun 28, 2014 07:38 PM
82airborne82
15
Aug 31, 2010 11:38 AM
