quick intake question
There really are NO dual plane intakes for 240-300s Except for a few homeade ones. I made one it is very simple. all you do is split the plenum under the carb.
The divider goes right between runners 3 and 4. Then look at you firing order and you will see the pulses willtake turns on each side (just like the twin plenums on a dual plane intake on a V-6 or V-8) You must face the carb east-west if you go this route.
Do a search on the Fordsix.com forum for split plenum and you can find pics of the one I made.
Every production carbureted V-8 engine as sold by Detroit for forty years came with a dual-plane manifold . . . and that meant that while you often saw a 4bbl carb on top of these engines, effectively they were NOT 4bbl engines!! No cylinder ever was pulling from all four throats of that carb. All of those V-8s were really dual-2bbl engines. Since nearly all of the 4bbl carbs were progressive opening with vacuum secondaries, what each cylinder saw was a 1bbl carb at low speeds, and a 2bbl carb when it was putting out more power.
Now WHY do we think our sixes (and I might say, our poor little overworked sixes) will do their best with 4bbl carbs, and single-plane manifolds that have each cylinder using two throats at low speed and all 4 throats at higher output? To my knowledge, Detroit virtually never sold a V-8 with a single-plane manifold for any practical application.
WHY did almost all of Detroit's straight-sixes come with a (rather crude) log manifold (with a single 1bbl carb)?? Because it was the best choice for the engine? NO, they built 'em that way because it was CHEAP!!! Our beloved sixes were always the cheap, baseline, economy engine in any car or truck. If you wanted power, you paid for the optional V-8 . . . with its more expensive and sophisticated dual-plane manifold.
Now look at an Offy C or Clifford manifold. The runners, with considerably bigger cross-sections than anything in the factory manifold, also have big lovely sweeping curves. Without bothering to take any measurement, you can easily see that those aftermarket manifolds must have nearly twice the internal volume as the factory manifold . . . and maybe THREE times the volume of either half of a V-8 manifold!!! And THAT is the volume you are asking each cylinder in your poor little six to draw a vacuum against??!! It's a situation that no cylinder in any production V-8 engine ever had to face, not even close! So how on earth do you expect to get a good strong vacuum signal to the carb venturi and venturi booster, when the cylinder first has to draw on that enormous volume in the mainfold??!!
This was the situation the Offy Dual-Port addressed (if my elderly brain was working, I could remember the name of the Offenhauser engineer who devleoped it, but it's just out of reach . . .
). And the DP manifold was first developed for V-8 engines, which ALREADY HAD dual-plane manifolds, so you can see that Offy was trying to cut those half-manifolds by half or more again, so they must have felt that reducing internal volume, increasing charge velocity, and getting a crisp vacuum signal at the carb venturi were highly desirable to say the least! So the Dual-Port is a vast improvement over the factory manifold. A Holley 390cfm would seem to be the right size. Think again about the fact that looks are deceiving and that each cylinder on a factory V-8 with, say, a Holley 750cfm, will never use more than one-half (375cfm) of that carburetor. BUT, each cylinder on our six, with the Dual-Port, will draw first from BOTH primaries, then from all four throats of our 390cfm Holley, so it works out pretty close to the same as a factory V-8.
(For fun, think what happens on our factory V-8 with the 750cfm Holley if we replace the factory dual-plane manifold with an Offy Dual-Port (also dual-plane) manifold; each cylinder will still be drawing from only one primary and one seecondary of the 4bbl carb, but now the internal volume of the manifold has been halved (roughly) again, so the charge velocities and the vacuum signals seen at the venturis are greatly increased even over the original dual-plane set-up).
Back to the six. I think the Dual-Port/Holley 390 is a good set-up for us (especially if we also replace the CHEAP original exhaust manifold with something better). It's probably better for a hauler than a "street performance" engine because the runners are maybe going to get restrictive and maybe reach a stall point at high rpm. What's a better choice? Setting fuel injection aside, the best carburetion would be three sidedraft Webers on individual runners, but that costs a wad or three. A far cheaper choice would be to split an Offy C or Clifford manifold in half.
Start with the fact that an inline six is essentially two inline triples connected end-to-end; 1-2-3 is an engine, 4-5-6 is an engine. Keep this in mind when thinking about either intake or exhaust systems, either of which can be split 1-2-3 and 4-5-6. (BTW, a V-8 is not two inline fours joined at an angle; it is four 90-degree V-twins joined end-to-end)(which is why each half of the dual-plane intake has to draw from cylinders on each side of the vee).
I had an early Clifford single-4bbl intake, bought second-hand (otherwise I might just have bought a DP). Nice curves, but huge internal volume, so it might have been good on a race or performance six on a small car, but I was building an engine for a van; I wanted low to midrange torque and fuel efficiency, plus the crisp throttle response you get when there's a good vacuum signal at the venturis.
So I took a chunk of aluminum and carved a "splitter," a barrier that divides the Clifford in halves, 1-2-3/4-5-6. It runs from the base of the carb to the bottom of the plenum, isolating each half. I did make provision for a "balance tube" between the front and rear halves of the mainfold, but have not experimented with it. The splitter is narrow, maybe 5/16" wide, at the top where the carb sits, then it flares out in smooth curves to give the charge a kick in the right general direction, fore and aft. As I said, pretty simple to do. And with that one stroke I halved the volume that any cylinder has to draw vacuum against. (Don't ask for pix; I don't have 'em and don't know how to post 'em. Learning how to do that is on my list of new year's resolutions . . . again).
The question then is what carb to use. Each half of my split manifold has to draw from one primary and one secondary of a single 4bbl (there wouldn't have been room for two 2bbl carbs). That means I'd have to mount a 4bbl with the floatbowl pointed to the vehicle's right side (or left, just not forward). Some carb makers don't like that, and prefer the bowl aimed forward so that hard accelleration or braking doesn't foul up their metering (whether making a hard sweeping corner fouls up the metering, I haven't heard . . .). I don't think it would be much of a problem in normal driving, especially with a low performance work-van, and I've seen many carbs mounted sideways, but you might ask the carb company tech guys. Anyway, if you go this route you might decide that a 390cfm Holley is too small, because again, each cylinder is now only pulling from half of the carb, like a V-8; my choice would have been one of the 600cfm spread-bores. But I went another direction.
I briefly considered trying a Predator carb, a very interesting unit, and internally splitting IT in half, too, because it's huge, like 930cfm or something.
But I had an easier and probably better option sitting on the shelf, a Holley 2bbl 670cfm Pro-Jection. Remember these? The off-road crowd loved them because they kept working at any altitude, and better yet, any ATTITIDE; those guys really get radical!! It's a self-contained, bolt-on, throttle-body injection unit, and can be had with a closed-loop option that gives it feedback from an O2 sensor. With no floatbowl, it doesn't care what direction it's pointed. Ordinarily, a 670cfm Pro-Jection 2bbl is waaay too big for a six, but one more time, each cylinder will only be pulling from one barrel (Sorry, I'm with the Department of Redundancy Dept.)
I haven't tried it. The new engine, mostly finished, is sitting in a plastic garbage bag gathering dust. I sold the van, and saved the engine for a vehicle I just bought, a 1968 Ford P350 bread truck (a step van). When I have done everything else I have to do to convert the bread truck (which has a running 300-six) for my purposes, the last step will be to install this motor.
I'll post pictures. I will, I will.
FORDSIX PERFORMANCE • View topic - carb position on offy (not a DP intake)
I modded this intake back in 2004.
OTOH, the folks who've switched from a DP to a C usually don't go back.
My main question here is, did Clifford ever make a dual plane manifold, or is this something that the previous owner bolted onto the intake?
If so, it's still an Offy C, and will respond like one. The DP has internal runners that separate the top of the intake from the bottom.
You can see them on the six ports in this picture:
The back two holes are for the secondaries and come through the bottom, and the front two holes are for the primaries and come out the top.
Thanks for the info, I really appreciate it.
Luckily for me, there's a guy with a chassis dyno nearby, but the way to test this stuff, initially at least, is with oxygen sensors in each header tube (tell me you're NOT going to use that cheapo factory exhaust!). You weld bungs into each tube and get six sensors, one meter, and a six-position range switch so you can go back and forth checking cylinders. Now, the poor man's way to do this (and the only way I've ever done it before now) is to drill a little sighting hole in the top of each header tube a couple of inches out from the flange. After dark, with everything all ready to go and the engine completely warmed up, you run the engine at various throttle setting and look at the flame color in the holes: orange is rich, white is lean, and blue is what you want. Airline flight engineers on the big DC-6s and Constellations in the Fifties often set the mixtures on those big Wrights and Pratts at night in just this way. Later you can weld the little holes closed; what I did was weld a big nut above each hole so I could screw in a plug that I could remove later if I wanted another look.
I think that may be it.
Jim
