View Poll Results: Which 5th wheel hitch is best
Pullrite superglide
19.05%
B&W
28.57%
Reese
26.19%
other
26.19%
Voters: 42. You may not vote on this poll
5TH wheel hitch Poll
Old Jan 3, 2011 | 07:27 AM
fixdent's Avatar
fixdent
My only concern is when I purchase another Hitch (I have a Husky now), it the sidway tilting. Mine does not do this, and a pain in the butt if you have to block the truck up for hooking up, because of uneven ground.
Gordon
Old Jan 3, 2011 | 09:39 AM
porthole's Avatar
porthole
Gordon
These are not HD over the road trucks with the saddle close to the frame.
I absolutely would not buy a hitch that did not have a 4 way tilt head.
Campgrounds are far from level.
Old Jan 3, 2011 | 09:43 AM
porthole's Avatar
porthole
Originally Posted by Str8shooter
I installed a 880 lb capacity Harbor Freight hoist in the garage and use couple 6' - 7' nylon lifting straps to lift the hitch from the bed.
I have the18K Super Glide and that is 250 pounds.
I also have a winch in my garage, although not harbor freight.
Used it to remove the hitch and take the fiberglass tonneau cover on and off by myself.
New truck will never get in the garage. May have to find a tree for it now.
Old Jan 9, 2011 | 07:11 PM
RPARKER559's Avatar
RPARKER559
Results look pretty even across the board.. I guess Money is the biggest factor...
Old Jan 10, 2011 | 09:09 AM
sandyc's Avatar
sandyc
I have the one that comes from Ford, a 25K Reese. I like it and it's easy and simple to work with. I used a Ranch Hitch (gooseneck type) by Andersen for years, but decided to try what Ford offered. I think their all good, just get what your comfortable with.
Old Jan 10, 2011 | 08:40 PM
Delawhere?'s Avatar
Delawhere?
I have had the Reese 18k slider on my 03, and now have the 18K PullRite hitch. I like the way the PullRite wraps around the pin instead of the clamping method the Reese did. Both worked fine for me but on the RV net, some have expressed problems with the Reese opening up and dropping the trailer. I haven't heard of any problems lately, and this may have been fixed. But never the less, the PullRite wraps around the trailer pin and seems very secure. The customer service is top rate also, they have answered my e-mails and phone calls when I had a question, or concern.
Old Jan 10, 2011 | 09:17 PM
sandyc's Avatar
sandyc
The Reese 25K from Ford does not clamp together, it wraps around the pin. The old one's, I know nothing about.
Old Jan 14, 2011 | 12:27 AM
Johnnyturbo's Avatar
Johnnyturbo
Sandyc, I have just been quoted from my Ford dealer installation of this hitch for my 2011 F350 KR CC swb. I didn't get the fifth wheel prep from the factory and I noticed you have the long box and was wondering if this hitch is a slider? I like the fact it is engineered by Ford but this is my first swb truck as I have always has Ford sc lwb trucks. Sounds like you are happy with the hitch and its ease of use. Can you remove the hitch by yourself or do you need a winch type setup?
Thanks much apprciated
John
Old Jan 14, 2011 | 05:38 AM
fz1dave's Avatar
fz1dave
Super Duty
Well there's certainly no clear winner. Looks like they will all do the job.
MCG DAWG
Mar 16, 2017 03:03 PM
budhare
6.7L Power Stroke Diesel
46
Feb 19, 2017 07:58 PM
HouseMouse
All Things Towing
Dec 31, 2016 08:59 PM
Jace2016
Oct 28, 2016 07:34 AM
jmahle67
Dec 24, 2011 06:48 AM
