Transmission OD Flash/ Limp Mode
Old Dec 29, 2010 | 08:43 PM
TheBrettster's Avatar
TheBrettster
Hey everyone,
I'm having trouble with my buddies ford expedition. It seems hes got an issue that the transmission fuse under the hood keeps on blowing and the truck keeps going into limp mode. The first time this happened he took it to amco and they replaced a sensor (have no idea what it was). They replaced it and the truck was fine for a few weeks. Then he recalls going up an incline and at the end the truck went back into limp mode with the overdrive light flashing. Then i had a look and saw the fuse was blown I replaced the fuse and cleared the 9 codes that popped up (pretty much every transmission sensor showed up on the list) and the truck was fine for about a month. Now he went up a different incline and it did it again but this time you can clear the codes and overdrive will shut off but right when you put it into drive or another gear it instantly goes back into limp mode with the od light flashing.
Any input would help.
Its a 2000 Ford Expedition 5.4 fluid is not burnt.
Old Dec 30, 2010 | 06:35 AM
projectSHO89's Avatar
projectSHO89
Previous thread, same problem.
https://www.ford-trucks.com/forums/1...ght-is-on.html
Old Dec 30, 2010 | 03:26 PM
TheBrettster
Cool I'll have a look.
Old Dec 30, 2010 | 08:50 PM
TheBrettster
Thanks thats exactly what happened. The loom was resting on the collector.
flyboyd8
Apr 18, 2023 06:50 PM
LanaKila Peck
Mar 4, 2016 03:23 PM
Bill97
Aug 15, 2013 09:35 AM
rjp1965
Nov 3, 2011 03:28 PM
Texas450
6.4L Power Stroke Diesel
Nov 11, 2010 07:04 PM
