"limp" mode - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
"limp" mode
Old 10-26-2010, 11:20 PM
Texas450
Texas450 is offline
Texas450 is starting off with a positive reputation.
Exclamation "limp" mode
i decided to make a new thread about my problem instead of taking over the other one
1 month ago my truck went in to limp mode.... meaning the truck would not rev. over 2500 rpms
i turned the key off and on and the truck was back to normal.
1 week ago the same thing happened and i did same thing and every thing was back to normal
sunday the truck goes in to limp mode but this time i have a check engine light come on with a code of fuel rail pressure is too high
monday i take my truck to a diesel shop that i trust and they pulled the code and clear it....then they took it for a test drive and could not get the truck to repeat the problem (no limp mode, no engine light)
but the check air filter light came on for the first time ever... mechanic said that maybe the engine was starving for air and the fuel/air combo was off making the pressure to high....or the computer messed up and threw a false code
but untill it threw the same code they said to take the truck back
today everything was working fine. I was doing some local runs around houston. then about 3pm my truck goes limp again but this time i notice that the transmission temp gauge is reading cold...which make no sense...since the trucks been working all day and it was only shut down for about 15 mins before this happened
so i turned the truck off and back on and the temp gauge climbed back up to normal operation temp....i had no problem
then i made my delivery and shut the truck down again for about 40 mins fire it up and truck goes limp and noticed the trans gauge is on cold again....turned key off and on works great.
would the truck go limp if the trans temp gauge is to cold?
anyone have any advice?
Old 10-27-2010, 05:12 AM
senix's Avatar
senix
senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
wiring somewhere shorting? That is what I am thinking...Have also had your batteries checked? Those batteries do some wierd stuff when they are weak.
Don't think that is your issue but someplace like napa or autozone can test them for free.
Old 10-27-2010, 07:15 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
what tune do you have loaded? is there a stock, just DPF off tune?
As Scott mentions I would also look for a loose wire.. you did touch the sensors when you did the doc/dpf delete.
Sam
Old 10-27-2010, 03:33 PM
John7894's Avatar
John7894
John7894 is offline
John7894 is gaining momentum as a positive member of FTE.
Maybe check the electrical harnesses/plugs too. If that truck ever had the cab off maybe one of them never got put back on tight enough and you now have an intermittent connection??
Old 10-28-2010, 04:24 PM
Texas450
Texas450 is offline
Sam
I think you nailed the problem...hopefully! I changed the tune to stock w no dpf and seems to be running good...now we will have to check fuel eco!
Old 10-28-2010, 08:03 PM
Smoke2008
Smoke2008 is offline
Smoke2008 is starting off with a positive reputation.
I had my HPFP replaced at 117k miles, my truck threw a code and you could say went into limp mode. It acted like there was a transmission issue....but it turned out to be the HPFP, The cab had been off several times and I have never that elect / connection issues...good luck resolving you problem...keep us posted
Old 10-28-2010, 09:46 PM
Texas450
Texas450 is offline
how much did that run you if you dont mind me asking....
Old 10-29-2010, 03:13 PM
Texas450
Texas450 is offline
gone 2 days now with no proplems since changing the tuning.....still crossing my fingers.....
tex
Old 10-29-2010, 04:51 PM
Smoke2008
The repairs to my truck cost nothing, I have the 21 major engine componets / 200k mile warranty....I purchased that just before the truck reached 36K miles.....The repair would have cost....4200.00 ....the dealer billed for a little less than 3200.00 ....warranty repair.
Old 10-30-2010, 04:39 PM
Texas450
Texas450 is offline
3 days now and no issues....if I make it to 14 I will feel a lot better
Old 11-11-2010, 02:30 PM
Texas450
Texas450 is offline
well i would like to let everyone know that i got my truck back from the shop.....they replaced the HPFP.....and the truck seems to be running awesome!!! thanks for everyones help on this issue.....they said that the pump was not functioning correctly and this is what caused the truck to throw the code....
tex
Old 11-11-2010, 03:02 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
tex
Well Tex you don't have to answer but I have to ask: did they give you any crap about the DPF and the tuner?
Old 11-11-2010, 03:12 PM
Texas450
Texas450 is offline
hey stanley.... not really sure what your talking about?
Old 11-11-2010, 05:01 PM
senix's Avatar
senix
senix is offline
Hmmm look down, see DPF, do repair. I like!
Old 11-11-2010, 07:04 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
10-4 backdoor
sdcharger
1999 to 2016 Super Duty
06-13-2017 09:05 AM
schrabs0
05-28-2017 09:04 AM
jagodog
05-16-2013 08:40 PM
juggalo555
02-01-2012 10:30 AM
TheBrettster
1997-2006 Expedition & Navigator
12-30-2010 08:50 PM
Quick Reply: "limp" mode
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
