6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
EGR disable, or delete?
Old Oct 27, 2011 | 12:39 PM
  #31
FivePointo's Avatar
FivePointo
I used the Sinister kit that blocks the EGR off the manifold and plugs the supply and return coolant lines. No wastegate kit, I don't run a lot of boost my H&S Black Max is set in the lowest tune and defuels at 1100 F egt
Old Oct 27, 2011 | 01:42 PM
  #32
BROWN DOG KTM's Avatar
BROWN DOG KTM
So my SuperChips 1856 on lowest setting (for mpg) would be fine with the EGR block off plug kit ??
Meaning I shouldn't have too much turbo overboost driving normal ??
Old Oct 27, 2011 | 02:02 PM
  #33
FivePointo's Avatar
FivePointo
I am unsure how your tuner works, I went with the H&S because it wouldn't throw a code with the egr deleted. On the lowest hp setting no way you'll over boost Mine barely gets into the 30s
Old Oct 27, 2011 | 03:24 PM
  #34
fg250's Avatar
fg250
Originally Posted by LaxPlaya21
I thought the 210 and below it functions as normal, however anything above and it is completely disabled. I am however, just going by what I was told. Either way, I think I have left the 250 tune in too long without cycling the EGR and I am throwing a code when running anything that does cycle the EGR.
the newest version of the 210 cycles at idle...that's what I run mine on.
Old Oct 27, 2011 | 05:49 PM
  #35
BROWN DOG KTM
Originally Posted by FivePointo
... with the egr deleted. On the lowest hp setting no way you'll over boost Mine barely gets into the 30s
Did you remove the EGR valve itself ??
My stock boost gauge will show "4" in hard pull ...
My tuner will delete the EGR system but I'd think it keeps the EGR valve from functioning ... so it would prolly throw a MIL IF I removed the valve itself ...
Guys, fill in the blanks for me ....
Old Oct 27, 2011 | 07:37 PM
  #36
FivePointo's Avatar
FivePointo
I did remove the EGR valve. I actually ran the truck today foot to floor, no load mind you and my max boost was 32psi
Old Oct 28, 2011 | 12:10 AM
  #37
BROWN DOG KTM
... I replaced the stock elbow with an RPM+ anyway.
Linky or pic ...
Old Oct 28, 2011 | 02:09 PM
  #38
FivePointo's Avatar
FivePointo
www.elitedieselengineering.com - CarbonFiberCFMwithadapterplatetappedport
Superdave
13
Dec 26, 2019 04:04 PM
2006powerstroke90
Apr 1, 2017 09:54 PM
wisevoss
Mar 14, 2014 12:49 AM
stangr8cr
6.7L Power Stroke Diesel
Feb 22, 2014 11:24 AM
vloney
Jan 3, 2011 09:45 AM
