Keep it or sell it?
Old Dec 30, 2010 | 06:45 PM
  #46
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Your numbers are fine, Hubnut. Drive it and enjoy it
Old Dec 30, 2010 | 08:36 PM
  #47
Hubnut's Avatar
Hubnut
Thanks man.
Old Dec 30, 2010 | 09:49 PM
  #48
i eat hybrids's Avatar
i eat hybrids
Originally Posted by Hubnut
Hybrid eater,
You are RIGHT! Made the decision to keep her. No more waffling. I'm a PSD guy. Good or bad. Doesn't mean I won't cry like a baby if it dies next week though.
My Coolant and Oil temps (edge insight) were as follows under these conditions (no towing and truck empty--except wife's big butt).
72 mph highway (72 degrees air temp): It was primarily at 194/205, but would occassionally go to 196/206-207.
stop and go: 190-192/198-202.
Questions:
1. Are these number great, good, normal, an indication of clogging?
2. I understand the delta of 15 degrees signals a problem. But what is at the OTHER end of the spectrum? In other words, what's a really good (normal) delta?
I think your normal. Pretty much your at a 10-12 deg diff. I just got my EGR cooler, Oil cooler, EGR valve and turbo recondition mond.. Got the truck back yesterday and i got my edge insight CTS today in the mail. I hooked her up and running hard, 98 mph, 23 psi im running 208/213. Never got above a 5 deg spread. How many miles does your rig have?
Old Dec 31, 2010 | 06:00 AM
  #49
Hubnut's Avatar
Hubnut
29,000 miles. Wow, only 5 degree spread. I guess that indicates I might have some blockage already. Thanks for the info.
Old Dec 31, 2010 | 06:10 AM
  #50
gearloose1's Avatar
gearloose1
A couple runs (or a very long run) with VC-9 might do the trick.
Old Dec 31, 2010 | 08:25 AM
  #51
Misky6.0's Avatar
Misky6.0
Originally Posted by psdmikee
Got my truck a Scangauge for X-mas, sure enough, I had a 35deg. delta when towing , when I bought her I got the ESP too. This morning I picked her up from the dealer all fixed (EGR cooler, Oil cooler, Degas cap) at no cost to me.
Keep it, get the warranty, and fix it when it breaks. I plan on replacing her at 200k if funds permit, but until then....
At least give the new engines some time to see what failures occur, they should be good but only time will tell.
Great - thanks for posting your info!
Now you have to learn to drive looking out the window again
- rather than watching the scangauge2.
Kalabin
2009 - 2014 F150
Sep 16, 2014 07:38 AM
Jasonnoel
Apr 18, 2014 02:05 PM
jascross
Oct 24, 2011 09:18 PM
jclodfe2
Sep 14, 2004 02:08 PM
JasonBoBasin
1997 - 2003 F150
Mar 5, 2002 08:42 PM
