Borg Warner Transmission Help???
Old Apr 15, 2014 | 06:48 PM
Jasonnoel's Avatar
Jasonnoel
I have been through a ton of threads and have pretty much identified the transmission in the 1955 truck. It's got the original 6cyl and trans. It appears to be a Borg Warner 3 speed. Not the overdrive. It has the short open tail. Turns out the parts house doesn't know how to look this up to get me gaskets. Is their a specific model/name for this? Any help would be great. It has AF-7006-D on the housing. Thanks,
Jason
Old Apr 15, 2014 | 07:16 PM
38 coupe's Avatar
38 coupe
Van Pelt has a great amount of information available for transmissions (he also sells parts, too). Flathead Parts Drawings-Transmissions
Old Apr 15, 2014 | 07:33 PM
Jasonnoel's Avatar
Jasonnoel
I've seen the drawings. And had hoped I could get parts sooner from Napa or something. Worst case I'll have to call them. But I still would like to know the proper name for these.
Old Apr 15, 2014 | 07:58 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It's a T-86. NAPA doesn't have anything but the rear seals. There are top and side-loader variants as well as Jeep, IH, GM et al versions of it with variations on several parts. Van Pelt is the best source for Ford versions.
Old Apr 15, 2014 | 08:05 PM
raytasch's Avatar
raytasch
Believe Nothing
Gaskets are very easy, quick and cheap to make.
Old Apr 16, 2014 | 09:37 PM
Jasonnoel's Avatar
Jasonnoel
I used T-86 to get a new tail shaft seal. And made new gaskets myself. Should be in good shape. Everything else looked good.
Old Apr 17, 2014 | 09:08 PM
Mac VP's Avatar
Mac VP
55 Ford trans
Hi Jason....saw this thread and thought I' respond since we were mentioned as a source. If the trans has the 9 bolt side cover, it's a Ford design unit. The light duty 3 speed trans never had a "name" aside from the LD reference for light duty. Totally different from the Borg T86 design, although the rear oil seal was the same. Shifter shaft seals are different. Gaskets are different, and synchros are different.
If it turns out you need any other parts for it, let us know.
Regards....Mac VP
VANPELT SALES
Jason
Old Apr 17, 2014 | 09:59 PM
Jasonnoel's Avatar
Jasonnoel
Regards....Mac VP
VANPELT SALES
Mac,
Thanks for the heads up. I'll see exactly what we have. It's great to have that information now. We restore these old trucks, and see all kinds of transmissions. Usually 3 on the tree with these. Someone converted ours to a side shift.
Old Apr 18, 2014 | 02:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B8AZ-7153-A .. T-86 3 M/T Gasket Set (no overdrive) / Obsolete
1953/62: F100/250 & misc Ford Passenger Cars.
BOWMAN SALES & SERVICE in Bowman ND has 3 = 701-523-3257.
WESLEY OBSOLETE PARTS in Liberty KY has 3 = 606-787-293.
FREESE MOTORS in Monticello IA has 5 = 319-465-3541.
MILLER OBSOLETE PARTS in Binghamton NY has 8 = 607-722-5371.
NOS PARTS LTD in Waxahachie TX has 18 = 972-937-2201.
Cougar54
Oct 20, 2016 03:22 PM
Bruin52
Feb 1, 2005 12:41 PM
Monsta
Car/truck Buying Advice
Oct 10, 2004 08:01 AM
97bluef250
1997 - 2003 F150
Dec 14, 2001 07:26 PM
94van
Nov 2, 2001 02:54 PM
