But you also have to know: Number of splines on pinion, which way you gear rotates, and the pinion shaft diameter. But summit has gear ratios form 2.86:1 up to the 7.33:1
NO.... I meant ratios avalable from factory! I dont want a new one, I was just curious.
I think in that case it was 4.11 for the ford 9 inch code 19 with a capacity of 3750 lbs according to my JBG magazine. With the dana 60 with code 28 having 4.56 gears as the highest overall ratio. Hope this is what you were after.
