390 engine to 302 engine
Old Dec 28, 2010 | 10:15 PM
proudtruck's Avatar
proudtruck
Question 390 engine to 302 engine
my dad is wanting to change engine from a 390 to a 302 is this possible with out putting a big hole in the pocket found engine already but what else will be need to modify to make it work by the way its a 1974 F-100 pickup
Old Dec 28, 2010 | 10:32 PM
ford390gashog's Avatar
ford390gashog
You will need new mounts , new tranny and all the other little parts. Why go through the hassle to downsize?
Old Dec 28, 2010 | 10:55 PM
redsuperduty's Avatar
redsuperduty
Stick or auto? You can just change the bellhousing on a stick, auto you will need a different tranny. Motor mounts are different, but not an expensive problem. All the brackets are also different, what all do you get with your 302?
I bet his reason lies somewhere in your user name ''ford390gashog''.
I love FE's, but they love gas!
Old Dec 28, 2010 | 11:17 PM
proudtruck's Avatar
proudtruck
its a 3 speed on the column are the brackets i need the same as the 5.0 mustangs cause i have those and i also have new motor mounts could i use th t5 out of a mustang
Old Dec 29, 2010 | 12:00 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
All the expense in swapping crap over will buy several tanks of gas. Why bother for maybe 1/2-1 MPG improvement?
Not to mention the power will be halved.
I would consider swapping the 3rd member (around $50-75 from JY) to a 3.25, 3.00 or even a 2.75 if mileage is really that much of a concern.
Josh
Old Dec 29, 2010 | 12:02 AM
Bullitt390's Avatar
Bullitt390
BTW it's the frame PERCHES that need to be swapped.
Also consider you may need a different intermmediate driveshaft.
Josh
Old Dec 29, 2010 | 08:28 AM
proudtruck's Avatar
proudtruck
Josh
what is the 3rd member
Old Dec 29, 2010 | 08:39 AM
jim collins's Avatar
jim collins
Differential
Old Dec 29, 2010 | 06:54 PM
Bullitt390's Avatar
Bullitt390
For a Ford 9 inch, the center-section is removeable has several "nicknames"...
3rd member
Drop-Out
Center-Section
Pumpkin
They can be had fairly cheap in most junkyards and just requires pulling the axles and disconnecting the driveshaft. Some silicone and new gear oil and you're good to go.
Not sure what you are running now, but if you have a 4.11 to 3.50 rear ratio, going to a 2.75-3.00 can make a good sized difference in fuel economy.
Josh
Old Dec 29, 2010 | 07:08 PM
F-250 restorer's Avatar
F-250 restorer
If you are looking to do it w/o spending much, then I would nix the idea. I've been that route. But I went from a 390 to a hp 300. Everything is different, from rad. hookups to throttle linkage, and ten things you didn't think of. Each means $.
I wanted to keep the 390 horse power, but gain 50% better mileage. I actually ended up doubling my mileage with the same towing/hauling ability--but it was not cheap. It is much cheaper to gain hp out of a v8 than an inline six. However, the 300 (4.9) produces peak hp at a much lower rpm than a v8.
Good luck.
Old Dec 29, 2010 | 07:25 PM
73 fourxfour's Avatar
73 fourxfour
I agree.....gear swap not an engine swap. Also with all the money you save, get rid of the points and run a good electronic ignition, coil, wires, plugs, etc. Also get a modern cam, a modern intake, a small 4 barrel carb, shorty headers with a good exhaust. You'll spend 1/4 the money, get better mileage, and it will perform much better. My papa always said, "son, there's no replacement for displacement."
Doogan
Dec 28, 2016 09:35 PM
Jimmy Vance
Sep 23, 2016 01:38 AM
abyars111
20
Feb 14, 2012 09:24 PM
leontono_leon
Apr 12, 2011 07:38 PM
timmer100
Feb 8, 2008 10:09 AM
