hey steve 83 or anyone else
please stere me in the right direction. my bronco failed emissins for NOx . could a bad catalitic converter cause this or am i heading in the wrong direction. any help will be appreciated
thank you
JUST TRIED TO GET MY 88' INSPECTED AND IT FAILED BOTH ...HC(PPM).. AND NOx
HC(PPM) STANDARD 155 AT HIGH SPEED I GOT 173
STANDARD 159 AT LOW SPEED I GOT 160
NOPPM) STANDARD 1508 AT HIGH SPEED I GOT 1987
STANDARD 1624 AT HIGH SPEED I GOT 2409
WHERE DO I START???? I CHANGED THE OIL, REPLACED AIR FILTER PCV VALVE AND BREATHER FILTER PUT IN NEW PLUGS AND WIRES, RXP FUEL TREATMENT FOR EMISSIONS. WILL THIS MAYBE DO IT OR DO I NEED TO GET A DIAGNOSIS FOR THE EGR.
Check your timing and make sure it is not advanced. NOx is usually a result of high temps. An advanced timing increases cylinder temps dramatically. According to a car specialist in our area most HC's are from having dirty oil, so go in with fresh oil.
When I brought my 1990 Bronco (351W) in for emmissions it also failed. What I did was give it a full tune up: spark plugs, spark plug wires, adjust timing, oil, air filter, also it turned out one of my vaccum hoses was broken. I found this out by going to pep-boys and having it put on a diagnostic machine. Only 20 bucks!
