Sponsored by: Real Truck
Gear swap directions
Old Oct 21, 2006 | 09:14 AM
billbain's Avatar
billbain
Anyone know of a source for directions to swap out and set up the gears on a 10.5? Thanks!
Old Oct 21, 2006 | 02:27 PM
ReAX's Avatar
ReAX
It takes specialized tools to do it correctly and easily. For the most part it is a remove and replace, after that you would have to tinker to get the backlash and preload right. The carrier portion of the install will be identical to any dana or corperate axle.
Old Oct 21, 2006 | 07:18 PM
Geneoh's Avatar
Geneoh
Randys ring & pinion, do a search it will come up.
I think you'll find if you have to ask you maybe better off finding
someone with the correct tools and exp.
Gene
Old Oct 21, 2006 | 07:23 PM
billbain's Avatar
billbain
Thanks, I have experiance with other axles but if there are special tools for the 10.5 I may have to farm it out.
Old Oct 21, 2006 | 07:43 PM
EnviroCon's Avatar
EnviroCon
Normally I would say take it to a pro, but if you already have experience with gears and have, or can get a hold of, the usual tools needed to do a gear job, dial caliper, case spreader, Vernier caliper, shims, pattern grease, etc. Then go to the below link, get a 72hr subscription for about $10 to a service manual and download the specs and instructions you need.
http://www.motorcraftservice.com
Byron Sanders
Feb 8, 2011 02:21 AM
sdloe
May 20, 2009 07:28 AM
michaelbrainardatwor
Jun 28, 2006 01:36 PM
lakecityg
Mar 15, 2006 08:05 AM
Katmandu
Nov 8, 2005 12:12 PM
