Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
air brake problems
Old Dec 26, 2010 | 09:59 PM
6t56's Avatar
6t56
air brake problems
I have a 1998 f-800.It has the automatic slack adjusters,but i think there stripped out or something?I have to get under the truck about twice a week,sometimes more to tighten the slack adjusters.I've never had them off so i dont really know how they work,but i can feel them click when i tighten them.Is it possible for them to strip and back themselves off?
Old Dec 27, 2010 | 12:01 PM
7DF250's Avatar
7DF250
I don't know much about them but I had a similliar issue with mine on a 99 Pete. Swapped them out for the regular old driver adjustable ones. A couple people told me that the are automatic but do require periodic adjustment and they do wear out or go bad pretty often. Is it on every axle or just a couple?
Old Dec 27, 2010 | 12:09 PM
6t56's Avatar
6t56
Both front and rear passenger side only,its a single axle truck
Old Dec 27, 2010 | 02:54 PM
petey shoes's Avatar
petey shoes
auto slacks tend to be quite reliable. they do, however, have finer teeth in gearsets, and can wear and "skip" causing what you describe. do you have abs? are brakes wearing uneven from side to side and/or top to bottom? if you replace- use same product, (autos), or if you go manual, change them all.
Old Dec 28, 2010 | 08:39 PM
rbaker6336's Avatar
rbaker6336
Slack adjusters (manual or auto) are designed to back off under high braking pressure applications to keep from breaking the drums.With wear they will back off under lower pressure.
With auto slacks you should rarely have to manual adjust them but should be checked on occasions
The front have a lower back off pressure than the rear so make sure you get the correct ones
warren e
Jun 20, 2017 11:55 AM
cuazman
May 21, 2016 06:29 PM
yerblor
Aug 1, 2011 11:09 PM
reddog99
1983 - 2012 Ranger & B-Series
Mar 28, 2008 06:57 PM
sierra5.3
Mar 1, 2005 03:58 PM
