Sensor Sequence???
Old Dec 26, 2010 | 04:29 PM
Tater50's Avatar
Tater50
Sensor Sequence???
Someone give me the sensor sequence as the PSD 96-97 7.3 cranks & fires.
PCM controls everything; correct? Then what ignites the others? Got to be a sequence for the others. ICP, IPR, CPS & etc. If there are others, please advise!!
PS Trying to place some info in my head when I am faced with problems, now & in the future.
Later/Tater
Old Dec 26, 2010 | 04:54 PM
Action4478's Avatar
Action4478
Cps reports that the engine is turning over . PCM reads ICP & tells IPR what it wants based on TPS .. Fuel volume is controlled based on (mainly) EOT ...
Old Dec 26, 2010 | 07:36 PM
Tater50's Avatar
Tater50
Good
On my 97; I have to unplug the ICP to get it to run; runs on about 6 cylinders: so, if I understand correctly: the PCM starts reading the ICP & trys to tell the IPR what to do, but if the IPR is defective; wrong signals are received; the defective regulator sends the wrong fuel pressure to the injectors; causing it to run rough.
Close or no cigar???
Thanks Tater50
Old Dec 27, 2010 | 08:15 AM
Action4478's Avatar
Action4478
Unplugging the ICP sensor makes the PCM assume ICP , at idle it will assume aprox 724, it also uses other inputs to guess . Have you pulled the valve covers & look at the oil spill spouts while cranking ?..
Old Dec 27, 2010 | 08:58 AM
Iallwork's Avatar
Iallwork
Tips - Idea - Hints
Tater have you seen this link it has alot of acronyms and short discriptions of what they are and do.
Old Dec 27, 2010 | 09:21 AM
89ford73's Avatar
89ford73
If you unplug the icp thqt 1means the sensor is bab 2 means the computer hqs to guess what the pressure actually is. It wont make the truck lose cylinders that is a problem with the under vale cover wire harness it sounds like you have two issues goin on at the same time. If its automatic does the transmission shift hard?
Old Dec 27, 2010 | 09:26 AM
89ford73's Avatar
89ford73
The fuel pressure stays constant no matter what. The regulator "ipr" regulates the oil pressure going to the injectors to make them fire harder
Old Dec 28, 2010 | 10:50 AM
Tater50's Avatar
Tater50
Sitting 3 years
97 has been sitting 3 years.
Could only get started w/ICP unplugged; ran rough
Could only get 20 MPH; so trans did not shift
So, what I am looking at: should unplug all sensors & make sure all these connections are clean.
Rick: will remove the IPR first, since I have another one & eliminate that potential problem. Removal of Valve Covers?? Have not done that yet; will do the above first.
Iallwork: thanks will take a look at that.
89Ford73: thanks for the input
Later/Tater
Old Dec 28, 2010 | 11:25 AM
Tater50's Avatar
Tater50
Good Info
Originally Posted by Iallwork
Tips - Idea - Hints
Been a gas guy for a long time; love the diesels: this is good info. My 97 is not a MUST GO right now; it is just a project/parts truck, but I think with you guys help, I will get it running.
It looks like the best starting procedure for a truck that has been sitting for a long time: is to make sure ALL electrical connections are clean; fuel is clean; batteries are charged. I have not cleaned ALL connections; that is the first thing I will do when the weather permits; then proceed.
With Rick's & others help: knowing the starting/running sequences is vital in determining the defective parts. Would be a real head scratcher if you do not know the sequence.
Later/Tater
Tater50
87
Feb 6, 2011 02:40 PM
Tater50
Jan 28, 2011 08:33 AM
Tater50
Dec 29, 2010 05:53 PM
Tater50
Dec 11, 2010 06:02 PM
my93
Mar 31, 2009 01:47 AM
