302 torque sequence for mains
Old Mar 28, 2009 | 10:13 PM
my93's Avatar
my93
What is the sequence to torque the mains of a 302, 1993. Anyone have a diagram? My manual does not address the sequence.thanks
Old Mar 29, 2009 | 12:09 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
You need to start with setting the thrust bearing first on the third main and then work to each end. Start at about 30 ft/lb then then about 50 ft/lb then to final torque.
You set the thrust by prying the crank towards the front of the engine to square up the thrust faces for even load/wear.
Hope that helps.
Old Mar 31, 2009 | 01:47 AM
fordeverpower's Avatar
fordeverpower
sounds good, it seems i get stuck sanding on federal mogul bearings for proper endplay, but not with clevite bearings.
tomkin
6.7L Power Stroke Diesel
Nov 6, 2016 11:56 AM
#01truckfan
Sep 11, 2015 05:03 PM
oldtexasdog
Sep 22, 2011 10:09 AM
rustyolred27
Apr 26, 2009 05:53 PM
my93
Mar 31, 2009 07:08 AM
