EOT/ ECT Large Differential
Old Dec 28, 2010 | 04:51 PM
  #46
TampaDave's Avatar
TampaDave
I will have an update by the weekend. New oil Cooler and New Coolant Filter( if the mail gets it here), New engine coolant, New Engine Oil.
I read in one of the other threads,, that "properly maintained these engines will go a million miles", after this investment in parts I sure hope so. Thanks for all the good advice.
Old Dec 28, 2010 | 05:20 PM
  #47
69cj's Avatar
69cj
Just my op. but I'd do the egr cooler while in there. That is where high coolant press. would come from. Still the result of the oil cooler.
Old Jan 1, 2011 | 12:18 PM
  #48
TampaDave's Avatar
TampaDave
Update, New Oil Cooler, New Oil, New Oil Filter, New Coolant, New dfuser Coolant filter.
EGR Cooler is only two months old,
Test Drive, 192/ 194 -196 ECT/ EOT
Test Drive pulling the 11K trailer at 70-72 mph, highest ECT was 211. EOT was 220.
I think that will work for me.
Old Jan 1, 2011 | 12:23 PM
  #49
gearloose1's Avatar
gearloose1
Happy New Year TampaDave!
Glad it worked for you.
Old Jan 1, 2011 | 12:27 PM
  #50
TampaDave's Avatar
TampaDave
Happy New Year Gearloose1,,, I appreciate the advice, would have not got through this without the advice I got out of this forum.
Old Jan 1, 2011 | 01:34 PM
  #51
69cj's Avatar
69cj
Lookin good tampa dave.
Old Jan 1, 2011 | 01:54 PM
  #52
gearloose1's Avatar
gearloose1
Definition of proper maintenance, see this:
https://www.ford-trucks.com/forums/1...6-0-6-4-a.html
Designed life of 6.0 when properly maintained:
B50 life is 350,000 to 375,000 miles, depending on who you talk to.
5. What is the expected life of the VT-365?
The VT-365 comes with a limited engine warranty of 5 years, 150,000 miles. In reference to life, this engine has a B50 life of 375,000 miles in medium truck applications. This far exceeds the typical engine requirements of the RV application.
B50 Life: This means that 50% of the engines at this mileage will require a major overhaul.
International VT 365 engine
That is comparable to the Cummins 5.9:
What is the B50 life of a 5.9L Cummins?
The Cummins ISB has a B50 life of 350,000 miles.
Cummins Diesel FAQ | Frequently Asked Cummins Diesel Questions
How I arrived at 1 million miles.
B50 life of say, 350,000 miles in medium duty use.
That is roughly 6,000 to 7,000 hours.
In light duty use, this can easily double.
That gets you 700,000 miles or 12,000 hours or thereabouts
That is 500 days, or roughly 1.3 years running around the clock.
Which just happens to be the normal overhaul interval of a marine diesel --- about 1 or so year of continuous running.
To go from 700,000 to 1,000,000 miles require a moderate improvement over the average.
That means synthetic oil, a rigorous maintenance schedule, and generally, catching problems as early as possible.
Where I am now: 275,000 miles.
I think I can confidently see this motor to 500,000 miles.
1 million? Probably the next owner.
BryanStein
May 29, 2014 10:09 PM
Super Duty Daddy
Mar 18, 2012 11:38 AM
WhiteBeast-05-powers
Sep 16, 2011 07:18 PM
carmk
Sep 1, 2011 08:10 AM
highsmit99
Jul 20, 2011 05:13 PM
