ABS Light
Old Feb 24, 2011 | 05:49 PM
KH85's Avatar
KH85
ABS Light
Ok guys I was driving yesterday and my ABS light came on. Wasnt braking or anything crazy, nothing changed as far as the truck an how it runs/drives/barkes. The only thing I have noticed is a few weeks ago I started to hear/feel a kind of "click" noise coming from the front left wheel area when under braking, almost like my u-bolts where loose, but I checked everything and all is tight and secure.
I went and had it scanned today and there was no codes stored at all.
My question is should I be concerned? Is this a common problem with our trucks? Or a common part that goes bad that causes the ABS light to go on?
Thanks in advance.
Old Feb 24, 2011 | 06:08 PM
BillyBob69's Avatar
BillyBob69
Watch your speedometer close. Does it kind of falter until you hit about 30mph then start working right? If so replace the VSS, (Vehical speed sensor) on the top of the rear differential.
Old Feb 24, 2011 | 06:53 PM
Bonanza35's Avatar
Bonanza35
Not sure but please keep us posted.
Old Feb 24, 2011 | 07:28 PM
KH85's Avatar
KH85
My speedometer isnt acting up at all an im not getting any sputtering or anything at all. Truck is acting and driving perfectly normal as of now.
Unless anyone has anything else that might help I guess ill just keep on truckin an see what happens.
Thanks for the help.
Old Feb 24, 2011 | 07:41 PM
Franko72's Avatar
Franko72
Molon Labe
My truck was perfectly normal with an abs light on also. a new VSS fixed it.
