Smog pump bypass pulley
Old Mar 21, 2007 | 01:16 AM
Jrock909's Avatar
Jrock909
Guys I bought a cheap bypass pulley for my smog pump since it locked up on me last week. Well I got the pulley yesterday and it bolted up just fine, but the problem I am running into right now is the belt is squeeling and it's a gatorback belt? Do you think after running the older belt on the newer bypass pulley that would be the reason it's squeeling? I also noticed that the bypass pulley like in the link below is smaller than the original bypass pulley, that could make my belt a tad longer to. This is on a 92 F-150 302EFI motor also. It's a 302 though and it should work fine, I didn't have any problems before I removed the smog pump.
http://cgi.ebay.com/ebaymotors/Auto-...spagenameZWD1V
Old Mar 21, 2007 | 06:59 AM
frederic's Avatar
frederic
Squeeking belts typically mean slipping, due to not enough tension, or a warn belt. Since you said the pulley is a smaller diameter I'd guess that the tensioner isn't providing enough pressure and the belt slips a bit.
Personally, I'd take a string and route it around all the pulleys, and buy a different length built and skip the bypass pulley you added entirely.
I did that on my 351W powered F350 with no problems.
Old Mar 21, 2007 | 07:22 AM
Conanski's Avatar
Conanski
Check the belt for alignment WRT the new pulley, it may be offset relative to the rest of the pulleys and it doesn't take much to create noise.
Old Mar 21, 2007 | 12:26 PM
eco's Avatar
eco
I looked into that a little while back, and the techs at Ford Racing told me that it was for Mustangs only and that it would not work for a truck. So, I just went with a shorter belt which gave me more contact at the alternator which is nice because I have a 3g alternator and some aftermarket accessories and thus more load at that pulley.
mwilliams0326
Feb 21, 2016 12:51 PM
ricky1
Mar 12, 2013 06:51 AM
breno1987
21
Mar 3, 2012 05:49 PM
Fairlane466
Dec 18, 2009 08:51 AM
1994 F250: 351, C6
Jan 23, 2009 04:43 PM
