Sponsored by: Auxito
Lol...I need help with my rear!
Old Dec 22, 2010 | 09:15 PM
ibkd66's Avatar
ibkd66
The rear in my 99 f150 lariat went yesterday. It is my only vehicle and I need it fix asap. I need to find a rear but can't decode the numbers on it too begin the process. Can anyone help with this..PLEASE
35919A 3L559759816
Old Dec 22, 2010 | 09:57 PM
Bluegrass 7's Avatar
Bluegrass 7
Look for the axle code on your door jamb the post it here.
Old Dec 22, 2010 | 10:06 PM
ibkd66's Avatar
ibkd66
The truck is at my dads, but these are the two sets of numbers I took off the tag on the axle 35919A 3L559759816
Old Dec 23, 2010 | 11:42 AM
Tex1986's Avatar
Tex1986
It's 3.55 limited slip. Same thing I've got in my truck. You can go to a bone yard and get one. or you can rebuild it yourself. What do you mean by it "went out"?
Old Dec 24, 2010 | 06:00 AM
ibkd66's Avatar
ibkd66
Thanks for the reply. Rebuild it myself, that's funny. I couldn't rebuild it if it was made out of Legos! So if it's a 3.55 (gear ratio?), then by continuing using the numbers on the tag it would also be a 9.75" ... whatever that means?
Old Dec 24, 2010 | 09:48 AM
Tex1986's Avatar
Tex1986
Is it a 4x4 by any chance?
Old Dec 24, 2010 | 10:18 AM
rsylvstr's Avatar
rsylvstr
seems you are getting good responses, but you might get more if you posted in the
Clutch, Transmission, Differential, Axle & Transfer Case forum.
Old Dec 24, 2010 | 01:27 PM
galaxie641's Avatar
galaxie641
5.4L is a 9.75 everything else is an 8.8
Old Dec 26, 2010 | 07:32 AM
DJPRacer58's Avatar
DJPRacer58
3.55 ratio, limited slip diff, 9.75" ring gear
dfletcher
Oct 2, 2014 12:59 PM
lightningfan426
Feb 25, 2011 06:07 PM
bmacky14
1978 - 1996 Big Bronco
Feb 20, 2011 07:27 AM
Rich in CO
1997 - 2003 F150
Nov 13, 2006 07:24 PM
