87 C6 Modulator valve
Old Dec 20, 2010 | 07:18 PM
FSBARAK's Avatar
FSBARAK
Originally asked in 87-96 forums https://www.ford-trucks.com/forums/1...ml#post9706615
I removed the old modulator valve. As the bracket loosened, the valve started to come out with it, as though it was spring loaded. When fully removed,there is a steel rod sticking out of the hole.
The rod is about an 1/8" dia. and is located at 12 o'clock inside the hole where the valve goes into the housing. The rod moves a bit in the hole, but will not go back in far enough to get the new (or the old ) valve in.
I took the rod out so I could drive the truck, but it makes me nervous to leave parts out.
Any tips on putting this rod back in?
Thanks in advance.
Old Dec 20, 2010 | 11:06 PM
jk080's Avatar
jk080
Transmission Rebuilder
It sounds like you are talking about the modulator pin, but I don't understand what you mean by 12 o clock.
You shouldn't drive it without the pin, without the pin the pressures will be low and you run a risk of causing damage.
Try installing it with the pin in the modulator instead, it should be pretty straight forward.
Old Dec 21, 2010 | 01:22 AM
FSBARAK's Avatar
FSBARAK
When the old modulator came out, the pin was not centered in the hole that the modulator goes into. It appears to be in a separate hole, at 12 or maybe 1 o'clock, inside the main hole.
Is the pin supposed to be in the modulator and centered in the hole?
I've never replaced one of these things.
I should add that I bought this truck about a year ago. The previous owner apparently was not mechanically inclined. Among other things, he put the thermostat in backwards, drilled holes in the air cleaner housing, etc. It could well be that he put this thing together wrong also.
Old Dec 21, 2010 | 06:00 AM
stuart1's Avatar
stuart1
There is a valve in the modulator hole in the transmission case.
This valve has a bore the pin fits into.
It is not a tight fit.
Insert the pin into the hole in the modulator then install the valve.
Old Dec 21, 2010 | 09:38 AM
jk080's Avatar
jk080
I found this picture for a C4 but it is the same for the C6. It shows the valve in the case with the pin fitting loosly in the bore that is in the valve.
Old Dec 21, 2010 | 10:51 AM
FSBARAK's Avatar
FSBARAK
Thank you, gentlemen.
Old Dec 21, 2010 | 02:31 PM
FSBARAK's Avatar
FSBARAK
Problem solved, everything is back together and working like a champ.
Thanks again and the picture really helped.
tsarge78
Sep 26, 2011 07:40 AM
david moore
Sep 11, 2011 02:13 AM
mr.fordneck
May 4, 2011 08:26 PM
TexasTrash
Mar 4, 2010 08:53 PM
