Harness replacement
Old Sep 2, 2011 | 11:22 AM
david moore's Avatar
david moore
Harness replacement
2005 F -350 6.0 ok guys heres the question which harness ,5c3z-12b637-aa or 5c3z-12b637-ba ,went to the local ford dealership and found out production date was 11/13/04 and at that date they changed from aa to ab how can i tell the difference ,no tag on harness and its out of the truck now
Old Sep 2, 2011 | 12:08 PM
Unrealo4's Avatar
Unrealo4
I would get the up dated one. Its just a higher quality harness it should swap straight over fine.
Old Sep 2, 2011 | 12:19 PM
npccpartsman's Avatar
npccpartsman
The dealership should be able to tell you from your VIN number. Give Tousley Ford parts a call and have your VIN ready. Also, if the harness has a tag of any kind on it, it's probably got an International part # on it.
I can't see anything in your picture post but a tag that says "EDIT"
Old Sep 2, 2011 | 12:20 PM
npccpartsman
I wouldn't count on that. It could be a difference in MAF or EBP location as IIRC there were some placement differences, not to mention two different production plants.
Old Sep 2, 2011 | 12:51 PM
david moore
tousley quoted me 568.71 ,and said it is the 12b637- ba for my vin# ,local dealer wanted 990.00 (thats with 10% discount) wow ,thanks for the hook up
Old Sep 2, 2011 | 03:13 PM
npccpartsman
You're very welcome. I just got a harness from them for my truck. Very reasonable prices and very knowledgeable guys.
Old Sep 10, 2011 | 12:29 PM
david moore
clackity clackity clackity -- its ALIVE
H P O P , I P R , EGR DELETE , Engine Harness , and awsome help from all my friends on here , soon to come SCT,
<!-- / message -->
<!-- controls -->
Old Sep 10, 2011 | 01:54 PM
BLADE35's Avatar
BLADE35
Great you got it Fixed
looks like its been down awhile Great Day to see it go again
Did you take any pics of the harness replacement??
Old Sep 11, 2011 | 02:13 AM
david moore
no pics ,had to hock the camera to buy the harness ( lmbo) install was pretty easy, started at pcm and worked across, dont plug anything up ,just have to take your time and ease it around and under a few places ..... until i got to the last one (crank sensor),thats where the fun begain , to congested to get your hand in to plug up conector tried several things,removed ground under a/c compressor still not enough room to get your hand far enough to connect plug,tried useing a coat hanger,passed it thru from the back side of the engine cross-member past the motor mount,out the other side, taped the plug on to the hanger ,thought to myself your a pretty smart fellow,but when i tried to plug it in there was not enough room to line it up,back to square 1 ,popped in here and got the bad news LOL a/c comp has to be taken loose ,lossened it up ,moved it over,snaped plug on ,bolted a/c back,re installed ground on block, belt tensioner, aluminum intake tube, passenger batt.(not connected), ficm, air breather and tubes back to turbo,overflow tank,drivers side batt.,connected both batteries,topped off overflow with distilled water, Drank a glass of tea and fired her up,was music to my ears
Gothere
Sep 15, 2014 04:04 PM
Tommyquest
Feb 25, 2014 02:18 AM
daddykitty
Mar 17, 2013 04:31 PM
bullit340
18
Jan 19, 2012 08:50 AM
locomike
Nov 12, 2009 06:26 PM
