Shifting from reverse to drive problem
Old Mar 4, 2003 | 11:15 AM
shodgson's Avatar
shodgson
Question Shifting from reverse to drive problem
I have a 92 Explorer EB 4x4. My husband replaced the transmission fluid and filter several months ago. I now have a problem when I back up and shift into drive on an incline, it acts like it's in neutral. I apply the gas and the engine revs but it goes no where. It seems to only happen if I am trying to shift into drive when I'm on a hill. If I step on the gas pedal really hard it will finally kick into gear. Once or twice I have already been in drive and stop at a light, when I take off again it will act like it's in neutral until I've given it lots of gas then it finally kicks into gear. Any ideas on what this problem might be?
Old Mar 4, 2003 | 01:50 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Often that is a symptom of low transmission fluid or a misinstalled filter. Either of those will cause the pump to suck air instead of ATF.
rlay302
Dec 8, 2012 02:58 PM
gzbrockington
2004 - 2008 F150
Oct 20, 2010 05:05 PM
aaronlockhart
Mar 30, 2007 07:00 AM
GasMonkey
Mar 25, 2004 09:09 AM
big truck driver
Sep 15, 2003 05:27 AM
