I need to replace the 4 wheel indicator lamp switch on my transfer case. It has fallen apart. Does anyone know the part number of this switch or even more important, where I can order one from? I have spent hours on the net with no luck. The switch itself has only one threaded stud on it (like the studs on the starter relay). Help would be greatly appreciated. Thanks
I think I may have found my own answer. LMC has a part 47-0845 but they don't state what transfer case it is for. Also Standard Motor Products has a BWD part number FWD22 and so does Napa Echlin have a FWD22. The pictures of the FWD22 look good. I ordered one from Napa today and will let everyone know if it is the correct one when I install it.
For those that have been following along the Napa Echlin FWD22 DOES NOT relpace the 4 wheel indicator lamp switch in the Borg Warner 1345 transfer case. Will keep you posted if I find one. Went to pick up the Napa part today and it was not the correct one. Good thing they were nice enough to take it back.
Ordered the switch today from Rockland Standard Gear in NY. Karen, my contact person says they have one switch left. She was also nice enough to give me the Ford part number: EOTZ 7E440B
Hope this helps anyone who is looking for this switch.
