Damn Electrical!!!
Old Dec 15, 2010 | 11:58 PM
Bwillden24's Avatar
Bwillden24
Damn Electrical!!!
I was driving home the other day and got about a mile away from home and every light on my truck goes out and stayed out till I got home. Glad I didn't end up in a ditch or hit a tree or anything. What is the most probable cause for this issue? I have been looking into getting a new switch and pigtail but if I can get a better alternative or idea that would be great.
Lights have been working while I am trying to see if I can duplicate the problem, the only ones I have gotten to come on at all are the reverse lights but I already know that the wires to the tranny need to get fixed badly.
Also, I don't have a fuse layout for my box, if someone has a diagram for the fuse layout that would be very helpful as well. No blown fuses by the way.
Old Dec 16, 2010 | 12:06 AM
6fifty_f1fifty's Avatar
6fifty_f1fifty
What year truck do you have?
Sounds like you might have a loose body to chassis ground or something like that to cause a system wide outage in the truck...
Old Dec 16, 2010 | 12:10 AM
Bwillden24's Avatar
Bwillden24
1980 F100 with the inline 6
Old Dec 20, 2010 | 03:48 PM
UglyTruck's Avatar
UglyTruck
My 80 f150 used to do that. finally traced it to a loose ground screw for one of the headlights. they are a simple ring terminal screwed to the inner body with a 1/4" self tapping screw. grab a nut driver and start making sure all of the ones you can find are tight.
Old Dec 20, 2010 | 04:14 PM
glovemeister's Avatar
glovemeister
My dodge did that one night. It burned out and I had noticed a burning smell for a week before that but figured it was just the cat or something. Anyway, I pulled the switch and that sucker was burnt to heck. Common on Dodges, I would check it on your Ford.
Old Dec 20, 2010 | 06:27 PM
Bwillden24's Avatar
Bwillden24
I took the headlight switch out to look at it and it was all corroded and rusty so I cleaned it up a little and put it back in. My lights seem to be working but I'm not 100% on that, I don't have my reverse lights yet but I think that the connector to the tranny is bad so I gotta look into that. I was working on changing all the bulbs and noticed that theres some sort of putty inside of some of them and the connector for my license plate light wont reach the lens. I need to go and get some new connectors for the lights and some more new bulbs, some of the bulbs broke trying to put them in.
Old Dec 20, 2010 | 10:00 PM
Bwillden24's Avatar
Bwillden24
I was underneath the truck looking at the tranny and I see I have a leak and that the connectors are wet from tranny fluid. I'm going to clean that area up and tighten things down and see if the connector is still good, if not I'm gonna have to replace it. So far headlights and running lights are still working
Old Dec 20, 2010 | 10:47 PM
ctubutis's Avatar
ctubutis
That putty is to keep water from the electrical contacts, people like to use dielectric grease
for those purposes today.
Old Dec 20, 2010 | 10:50 PM
Bwillden24's Avatar
Bwillden24
ok, would that putty cause bad connections?
Old Dec 20, 2010 | 10:53 PM
ctubutis's Avatar
ctubutis
Not really....
Old Dec 20, 2010 | 10:54 PM
ctubutis's Avatar
ctubutis
When all your lights went out, what about things like the radio, wipers, heater fan? Did they go
out at the same time?
Old Dec 21, 2010 | 04:33 AM
Bwillden24's Avatar
Bwillden24
I don't have a radio and I didn't have the heat or anything else on, no rain that day either. i'm looking into all possibilities so i will look into all that as well, thanks
Old Dec 21, 2010 | 06:36 AM
ctubutis's Avatar
ctubutis
What I am trying to figure out is if it was your entire electrical system in the cab that got
knocked offline (in which case fusible links up near the battery are highly suspect) or if it
was merely only the lights in which case more possibilities open up (headlight switch, high-
beam switch, melted, shorted or damaged wiring, bad grounds, etc. etc.).
Old Dec 21, 2010 | 07:02 AM
Bwillden24's Avatar
Bwillden24
I took the headlight switch out and checked it, it had corrosion and rust on it, I'm going and getting a new switch today and bulbs to replace in my instrument cluster. I haven't checked the high-beam switch yet, I will look at that today as well, I don't know what all fuses i'm missing are but I know that there are a few missing. Do you know where I can get a diagram of what fuses are for what?
Old Dec 21, 2010 | 07:09 AM
ctubutis's Avatar
ctubutis
From Franklin2's diagrams:
