for those with an intercooler...
Old Dec 20, 2010 | 11:24 AM
deceptichop's Avatar
deceptichop
I am new here, however I do know in fact that Oreo is running an intercooler from a 6.0.
My buddy has a 2008 SD with the 6.4. He is upgrading his cooler and giving me his stocker.
I have a 1994 7.3 with factory turbo with boost increased to 10/15. I just purchased new injectors from Russ and am about to purchase a new IP. This new IP will be turned up, therefore my desire for a cooler.
Here is my question, I am aware that the stock coolers range from $100/200. BUT, this does not include the piping.
How labor intensive am i looking for the plumbing/piping to install an intercooler. Do I bring it to an exaust shop or something of that nature???
Thank you in advance
Old Dec 20, 2010 | 11:26 AM
joe f350's Avatar
joe f350
check out oreos gallery he got some pics of when he did his
Old Dec 20, 2010 | 11:32 AM
powerstoked!'s Avatar
powerstoked!
Hey j, the 6.0 cooler is a good cooler, but do know that they are a lot more difficult to install than the 7.3 coolers because they're bigger. I helped a buddy of mine down south install his, the piping can be a super pita, but i can give you a hand if you need it. Oh and i'll get on my puter in a min. And send you a pic of that pyro if you want it
Old Dec 20, 2010 | 11:38 AM
joe f350's Avatar
joe f350
i was talking to oreo last night he was saying use a 7.3 not to 6.0 cause the turbo has problem with pushing the volume of air that the 6.0 sucks in cause it so big
Old Dec 20, 2010 | 11:52 AM
deceptichop
will the 6.4 work? Its got to be better than the older 7.3 correct??
Old Dec 20, 2010 | 11:53 AM
joe f350's Avatar
joe f350
it might be to big ur turbo might not be able to push the addeed vloume of air
Old Dec 20, 2010 | 12:31 PM
oreocreaming's Avatar
oreocreaming
your on a catch 22 there bud. the bigger the cooler the colder the charge. but the larger the intercooler the harder your turbo will have to work to fill it up. i got no more then 4psi in my cooler but it ran like the n/a with 15lbs. if you wanna know if it will work, just measure his radiator and make sure if its as wide as yours. if it is then it will be fine.
Old Dec 20, 2010 | 12:32 PM
oreocreaming
if you get a 6.0 cooler, ive got everything you need to hook it up.
Old Dec 20, 2010 | 07:21 PM
deceptichop
good sh** Oreo!!! Once I land me a 7.3 or 6.0 cooler, I shall be in touch
Old Dec 20, 2010 | 07:47 PM
typefour's Avatar
typefour
Does the intercooler go empty when the engine is off? Cmon guys it creates a little lag but not much, I have tried both6.0 and 7.3, Not much difference.
Old Dec 20, 2010 | 08:08 PM
deceptichop
hmmmm, interesting. Russ, what is your thoughts on me running a stock cooler from a 6.4?? I know that motor is a newbie. Ive heard nothing but great things about it.
Old Dec 20, 2010 | 08:13 PM
oreocreaming
the factory turbo doesnt add much power anyways so you dont notice the lag. you notice the mpg gain though
Old Dec 20, 2010 | 08:24 PM
deceptichop
agreed Oreo. Thats probably why an aftermarket cooler for 6.0 OR 6.4 are $1500+
Old Dec 20, 2010 | 08:34 PM
oreocreaming
well, your motor doesnt have one, so any cooling is better then no cooling. you can find a nice small universal one off ebay. 2"-3" inlet is fine. the tubing to and from the intercooler alone will help.
Old Dec 20, 2010 | 09:33 PM
oreocreaming
