for those with an intercooler...
Old Dec 31, 2010 | 08:45 PM
  #61
Dave Sponaugle's Avatar
Dave Sponaugle
Looks like some nice fab work on the pipes.
All the salt I have run in for years plowing snow have about done my radiator support in on my 86.
Next year I think I am going to custom fab a core support and move my radiator back enough to get an intercooler in mine.
That would be cheaper than buying a different snow plow and get me a decent core support at the same time.
So I could kill two birds with one stone.
Old May 18, 2011 | 02:32 PM
  #62
snaponprofile's Avatar
snaponprofile
Did oreos truck have a DP upgrade or the stock junk? I'm trying to figure why the boost was so low.(4psi)
Old May 18, 2011 | 08:35 PM
  #63
towcat's Avatar
towcat
i have an aftermarket setup on my truck and the boost hits the same.
the 093 turbo is most efficent at 7-10 psi. any more you are making more heat than power.
Old May 18, 2011 | 09:42 PM
  #64
snaponprofile
Hey towcat, didn't know you were here too. Is the power the same considering the low boost or is it more?
Old May 19, 2011 | 12:35 AM
  #65
towcat's Avatar
towcat
I've been lurking here since 2006. the site is agonizingly slow with the data terminal in my car, so I visit when I am in the office.
Just recently, I tied a trailer weighing in at 10k gross to the *** of the CCdually that already tips the scales at 8k. I have a gross combined of 18k. went from the SF bay area to Reno, NV on I80. Kept up with traffic and was passing the big rigs on the grade in 4th gear. I can't ask for better and to top it off, my major chassis overhaul in 2005 is still intact save for oil changes, a few belt tensioners, and a couple of IP's I'd consider that pretty damn good for an old dog of a truck.
Old May 19, 2011 | 03:11 PM
  #66
snaponprofile
That is certainly good, I'm gonna go with a 7.3 unit though, I assume the cooling will be close to the results of the 6.0.
Old May 19, 2011 | 03:54 PM
  #67
oreocreaming's Avatar
oreocreaming
stock dp but you have to remember, I'm filling a intercooler for the 6.0 plus 6' of intercooler tubing.
Old May 19, 2011 | 04:00 PM
  #68
snaponprofile
Thats true, but the crappy dp probably hindered flow alot.
Old May 19, 2011 | 04:09 PM
  #69
oreocreaming
rodney instaled it on is truck and got 11psi unloaded
Old May 19, 2011 | 04:57 PM
  #70
snaponprofile
I bet he bumped the fuel screw quite a bit.
Old May 19, 2011 | 05:05 PM
  #71
oreocreaming
no more then I had mine.
Old May 19, 2011 | 07:05 PM
  #72
snaponprofile
Ok, I am gonna go for a stock 7.3 cooler. It should be enough.
Old May 19, 2011 | 07:17 PM
  #73
oreocreaming
not sure what the size difference between te two are.
Old May 19, 2011 | 08:20 PM
  #74
snaponprofile
Core on 6.0 is 1400
Core on 7.3 is 1040
Old May 20, 2011 | 12:05 AM
  #75
towcat's Avatar
towcat
both of you are looking at IC's that are at minimum twice the size of what I have, the ATS kit is roughly the same size as a Mitsu Evo IC and it's a bar and plate type IC.
I have yet to encounter a problem with heat soak on the IC.
