Blue spring--how do it??
Old Dec 17, 2010 | 05:33 PM
Hubnut's Avatar
Hubnut
Got the blue spring kit. Attempted to install this afternoon. No go. Two things: 1. How do you support the housing when breaking the fuel line nut? I couldn't get a wrench in there. 2. How do you get to that bottom right torx screw with the rad hose there? thanks.
Old Dec 18, 2010 | 11:12 PM
woodlander's Avatar
woodlander
I just finished the upgrade. Wish i woulf have done same time as thermostat as i had to take same stuff off. I had my son help and used a board to shove down on radiator hose as he unbolted lower screws. If i ever do again M going to just unscrew hose from thermo end ab
And get it out of way. It o ly takes a fe minutes after draining a few gallons of coolant out. My fuel pressure went up to 79 at one point then settled in at about 74.
Old Dec 18, 2010 | 11:16 PM
woodlander's Avatar
woodlander
Oh yeah i put a cresent wrench on the filter housing nut as i didnt have right size wrench. It only went on part way but held enough turn nut on fuel return line.
Old Dec 19, 2010 | 03:48 PM
bismic's Avatar
bismic
Here is a thread w/ a couple of ways to get the lower T27 Torx screw.
Like woodlander, I also had an extra set of hands to keep the radiator hose pushed down.
http://www.powerstroke.org/forum/gen...lator-job.html
Also:
http://www.restockit.com/t-27-torx-w...Allen%20wrench
But I would think that the local autoparts store might have it (save shipping).
Old Dec 19, 2010 | 04:34 PM
Hubnut's Avatar
Hubnut
That torx allen key looks like the ticket. Thanks Bismic! I guess I'll just remove the torx screws first, then try to break the return line. It's really stuck on!
Old Dec 19, 2010 | 06:03 PM
John Irwin's Avatar
John Irwin
Be careful to not let the fitting slide down the tubing and get lost down under. Mine had a tie strap on the line on it to prevent it, I was wondering what it was on there for, quickly figured it out.
Fandini
Oct 19, 2013 06:23 PM
Yahiko
Jul 17, 2012 11:42 AM
AJB201
Jun 20, 2012 11:08 PM
jtproudlogger
Jun 11, 2012 05:26 PM
nothercrash
Mar 4, 2011 11:11 AM
