Missing???
Old Dec 15, 2010 | 03:43 PM
Blankie's Avatar
Blankie
Missing???
I have a 96 F350 CC Stock except for Super Chip. Problem is that at 45 -50 MPH Engine seems to be missing that is the only speed that I notice it. Any ideas.
Old Dec 16, 2010 | 07:45 AM
riverrat41's Avatar
riverrat41
Is it setting a CEL?Does it just die for no reason?How old is the CPS(Cam Position Sensor).Can someone put it on a scanner for you that reads diesel codes?Does it have the same symptoms without the Super Chip installed?
Old Dec 16, 2010 | 06:43 PM
Blankie's Avatar
Blankie
No CEL, not shutting off, does not seem to affect the way truck runs. Just at 45 - 50 MPH or 1500 RPM it seems to be missing or surging. This happens when running at that speed not under acceleration.
Old Dec 16, 2010 | 09:22 PM
oldbird1965's Avatar
oldbird1965
Just a wild guess, try putting the SC on stock and given it a try. That way you can rule out that one out.
Old Dec 17, 2010 | 07:04 AM
Blankie's Avatar
Blankie
Thanks, I will give that a try next time out.
Old Dec 17, 2010 | 09:56 AM
Boohaha's Avatar
Boohaha
I have the exact same problem but my truck is bone stock, except for a lift and doing the 6637 thing.
Thought it might be a filter issue so changed the fuel and air filters and still had the same problem. Its weird cause as soon as you put a little more throttle to it it goes away and the truck takes off. My idle runs up and down about 50-100 rpm as well could be related.
I myself was wondering if it was a throttle position sensor problem, I know these truck drive by wire without a real throttle so maybe the contact points are getting worn in that spot?
Old Dec 31, 2010 | 02:37 AM
Boohaha's Avatar
Boohaha
Know this is a thread no no in most places but still haven't been able to figure anything out on this problem and just thought that maybe the topics came really fast and this one got missed by most of the regulars do to the lack of response.
Any help would be appreciated.
DBANDGB
Jul 15, 2014 04:46 PM
tractors55033
1983 - 2012 Ranger & B-Series
Oct 13, 2009 05:57 PM
78 ford f150
Dec 8, 2007 01:44 PM
CMWINTER
1997 - 2003 F150
May 29, 2003 07:29 AM
amsnss
Apr 17, 2002 09:28 AM
