Little help please
Old Dec 15, 2010 | 07:43 AM
r-kid's Avatar
r-kid
Little help please
I have a 2000 7.3psd f350 148000 miles. This morning I cranked my truck for about 10 seconds and it would not start, I waited and cranked it again and it still would not start. Then on the 3rd attempt it started. Alot of white smoke came out. The temperature was about 30 degrees I am in Florida. After driving it for 10 minutes it restarted fine. Any ideas why it would not start properly the first time would be appreciated. I would like to fix a future problem. thanks Ron
Old Dec 15, 2010 | 07:45 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
The first thing I would do Ron, is test your GPR. Make sure you have power to the glow plugs.
Old Dec 15, 2010 | 12:05 PM
429 f-100's Avatar
429 f-100
read the cold start winter sticky thread . first one in this 7.3 forum it will explain fully . hope this helps wes
Old Dec 15, 2010 | 12:59 PM
Fishin76's Avatar
Fishin76
I would agree with Miller_feed. For ~$30 from Napa, I would get a GPR-109 solenoid and just replace it. With the weather you have down there, not much use for one except when you get the rare freeze. They do go bad anyway.
A simple solution is to use the AIH relay for the glow plugs. It is the solenoid just to the south of the GPR (as your looking at the top of the engine.) You can delete the AIH and never use it agian, as it really isn't needed where your at.
Old Dec 15, 2010 | 01:07 PM
h2guy's Avatar
h2guy
Are you in the habit of waiting until the WTS light goes out before starting it?
You can get away without doing it when its warm but may not allow you to start it when its cold out, as it has been recently in FL.
metmop
Jul 7, 2012 09:32 PM
rtausn
Apr 22, 2012 08:37 PM
r-kid
Jun 25, 2009 08:20 PM
54-4U2C
Florida Chapter
Oct 13, 2008 08:39 PM
Tacoma Ron
Aug 4, 2003 02:00 PM
