Sponsored by: Real Truck
Acetone Victory!!
Old Mar 3, 2003 | 03:47 PM
MarkF250's Avatar
MarkF250
Acetone Victory!!
I finally did the acetone trick...I remove the badges first. Kinda a pain on the F-250 badge b/c they are on good. V-10 badges came right off with fishing line. Used braided fishing line b/c the monofiliment line brakes while sawing it behind the badges. It took longer to clean the adhesive off the truck and badge than it did to acetone. But with a little persistance it all came together. Have pictures in my gallery. Check it out if still looking to do this job. Didn't get a chance to do the one on the tailgate....started raining down here in South Texas and got cold.
Old Mar 3, 2003 | 08:12 PM
Quikirk's Avatar
Quikirk
Acetone Victory!!
Lookin good Mark
Old Mar 3, 2003 | 08:32 PM
4x4x4x4's Avatar
4x4x4x4
Acetone Victory!!
Old Mar 3, 2003 | 10:40 PM
Outpost22's Avatar
Outpost22
Acetone Victory!!
That really looks "first cabin"
Old Mar 3, 2003 | 11:04 PM
MarkF250's Avatar
MarkF250
Acetone Victory!!
Thanks guys!!!:
Old Mar 4, 2003 | 07:20 AM
99sdpstd's Avatar
99sdpstd
Acetone Victory!!
BEEEEAAAUUUUTTTTIIIIIIFULLLLLLLLLLLL!!!!!!!!!
Wow man that looks great. Thanks for the pic post. I have an early 99 is it true it can't be done on mine unless I buy new ones??????
Old Mar 4, 2003 | 07:41 AM
bddo's Avatar
bddo
Acetone Victory!!
The emblems look great!!!! I still haven't brought myself to do it yet. I actually purchased two new V10 emblems off of Ebay for $10, so I could practice on them!!!
GOOD JOB!!!
Old Mar 4, 2003 | 08:25 AM
LincolnHayes's Avatar
LincolnHayes
Acetone Victory!!
That looks sweet. I'm planning to do the same thing to my truck this weekend if the weather holds out.
LH
Old Mar 4, 2003 | 08:41 AM
ECM's Avatar
ECM
Acetone Victory!!
I'm not sure if this has been covered or not but I used a product called "GOOF OFF" as well as acetone to do my badges. What I did was tape off around the emblem with 3" tape (2 layers) and a garbage bag from the bottom of the emblem to the ground. Then I took a 3" paint roller minus the handle, dipped it in acetone and wiped the emblem 4-5 times then took another paint roller and dipped it in "GOOF OFF" and went over the emblem 2-3 times and all the black came right off. After the acetone softens the black the GOOF OFF removes all the black easily. Took maybe 5 minutes to do both side badges including clean up. BTY the red XL stayed just fine.
Old Mar 4, 2003 | 08:47 AM
bddo's Avatar
bddo
Acetone Victory!!
ecm,
Great Post!!! Sounds like you found a solution to one of the biggest issues regarding the acetoning.... THE TIME!!!!
Thanks.
Old Mar 4, 2003 | 08:53 AM
ECM's Avatar
ECM
Acetone Victory!!
Yeah, that GOOF OFF really helps. I started out using Q-tips and did the rear emblem in about 20 minutes, then I sat down and thought about what else I could use because I didn't have a paint brush.
Old Mar 4, 2003 | 09:31 AM
tankhead's Avatar
tankhead
Acetone Victory!!
Thats correct. I don't know what your build date is but mine is 4/98 and tried it but all that came out was a shiny black.
enduro4231
Apr 6, 2009 09:01 PM
NASCARTruckDude
1997 - 2003 F150
15
Aug 27, 2003 09:22 PM
SNEAKY F350
Aug 14, 2003 09:19 PM
viper69
Aug 4, 2003 10:18 PM
MarkF250
Mar 24, 2003 06:28 PM
