Sponsored by: Real Truck
Badge Removal??
Old Mar 25, 2009 | 09:39 PM
enduro4231's Avatar
enduro4231
Badge Removal??
In my never ending quest for a cleaner looking truck I'm considering removing the badges from my fenders and tailgates and I've got a few questions for someone who's done it before.
1. Are there locating pins on the badges, thus meaning there are holes in the fenders to line them up?
2. How strong is the adhesive used on them? Strong enough to pull off paint? My buddy took a Cummins emblem off his Ram and the adhesive was so tough that it ripped the paint in a spot the size of a quarter right down to primer.
Is there a special process I should do to remove them safely? Soak in acetone or adhesive remover or something? I don't want to use acetone because it would remove the black from the badges if I ever want to put them back on.
Anyone have pics of their truck with badges removed?
Old Mar 25, 2009 | 09:46 PM
System's Avatar
System
Prolocutor
If there are no pins, I've had very good luck with using waxed dental floss and slowly working it back and fourth breaking the seal. Not to say it works on every brand, but it has worked for me in the past.
Old Mar 25, 2009 | 09:54 PM
DAVE67FD's Avatar
DAVE67FD
Im not sure if there are locating pins but i would guess no. If confirmed there isin't try using a hair dryer to loosen the adhesive. You can use a heat gun but be carefull not to concentrate the heat in one area.
Old Mar 25, 2009 | 10:42 PM
tex25025's Avatar
tex25025
Yes, there are locator pins on the fender badges. I know because I removed them to put my custom badges in their place. I don't know if the tailgate has one or not because that is the only factory badge I have left. The fender badges, door badges and both oval badges I swapped.
Edit: On second thought I just noticed that you had an 02 5.4. They might still have locator pins, but I don't know bout that far back. Sorry, jumped the gun on that one.
Old Mar 25, 2009 | 10:46 PM
danyzf95's Avatar
danyzf95
tail gate I believe does have a locating hole
enduro4231's Avatar
enduro4231
Scratch that idea I suppose.
Old Mar 25, 2009 | 11:02 PM
enduro4231's Avatar
enduro4231
I suppose I should just give it a try tomorrow. Now if only one of the girls in my dorm will lend me their hairdryer...
Old Mar 25, 2009 | 11:14 PM
powerstroke72's Avatar
powerstroke72
Something that has worked for me in the past is a Bondo spreader. It's easy to work in at the edge of the emblems and just move it back and forth working it down the length of the emblem until it's off.
Old Mar 25, 2009 | 11:25 PM
Beerstalker's Avatar
Beerstalker
Yes the badges all have locating pins behind them on the fenders and tailgate. The only exception is the Powerstroke badge on the door if you have the diesel.
Old Mar 25, 2009 | 11:26 PM
enduro4231's Avatar
enduro4231
That's a downer. In that case, does anyone remember that website that sells the '05 up badges?
Old Mar 25, 2009 | 11:34 PM
Beerstalker
Any Ford dealer should be able to sell you the 05+ badges. I recommend talking to Ed (FTEPartsGuy).
If you want custom badges look at Billet Badges | Welcome
Old Mar 25, 2009 | 11:38 PM
enduro4231's Avatar
enduro4231
Yes, that was the one! Thanks Beerstalker!
Old Mar 25, 2009 | 11:52 PM
tex25025's Avatar
tex25025
I recommend him. He has done all my truck badges as well as the badges on my dad's 911.
Old Mar 25, 2009 | 11:57 PM
enduro4231's Avatar
enduro4231
Awesome! I suppose if I can't remove them it would look good to have '05+ badges on there, but all black with silver lettering instead of the other way around like stock is.
Old Mar 26, 2009 | 12:20 AM
bigtimebubba's Avatar
bigtimebubba
I just removed some badges tonight. I just used a hair dryer to heat the badges up and then dental floss on one side to break the seal got my finger underneath and then just gently pryed the emblem off. Super easy as long as you heat the tape up on them.
It won't pull the paint off but on certain colors and how old the truck is the color under the emblems could be a extremely different color.
