gpr led light
Old Dec 14, 2010 | 12:17 PM
429 f-100's Avatar
429 f-100
gpr led light
just changed my gpr out and added a led light to it so i can see time out. light did not work double checked wiring it is correct good ground but when i checked the glow plug side of relay it is soildly grounded all wires on outside look good i think it is inside valve cover i have seen in other posts here wires rubbing rockers and shorting to ground .sound like it to you guys ? the solinoid is working when ing is turned on solinoid actuates and power is on glow side for minute and a half as it is 25 degrees here today . ii think im ready to pull valve covers off . whatcha think wes
Old Dec 14, 2010 | 01:06 PM
Mark250's Avatar
Mark250
Have to ask an obvious question here - did you get the LED to work at all? Do you have the polarity reversed? - an LED will only work one way. Probably need to put a multimeter on the GPR to see exactly what is happening.
Old Dec 14, 2010 | 01:13 PM
woodnthings's Avatar
woodnthings
Where do you have the power lead from the LED going?
I grounded my LED in the dash area, near the LED. Then I ran a single wire (Orange one) to the GPR for the 12V Power. I hooked this lead to the post going to the GP's. If you are getting power off of that post it should work. Did you verify the LED works?
Old Dec 14, 2010 | 02:04 PM
429 f-100's Avatar
429 f-100
mark i thought all leds were polarity sensetive but this light (dorman 84926) said just one wire to ground and one to assy and no marks on light about this side is pos and other is neg. so i just hooked it up . so i just pulled light out of the truck and used a jump box to to light first way no light thought mabey bad light hooked other way and it worked took back to truck hooked up other way and wa la she worked . so at least im not second guessing my electric skills . and i was thinking im reading ground thru the glow plugs . sometime i feel like a idiot but at least i get it eventully . thanks for all replies guys wes
Old Dec 14, 2010 | 02:12 PM
429 f-100's Avatar
429 f-100
ken i ran mine same as you but just had led backwards it wasnt marked so i just hooked up but as you can read in post above i got it fixed now thanks for your input both of you guys made me think that it was backwards wes
Old Dec 14, 2010 | 06:24 PM
woodnthings
Well at least you got it figured out!
Old Dec 15, 2010 | 06:45 AM
429 f-100's Avatar
429 f-100
yea thanks , even though it was a simple thing nice to move on now . for over twenty years of wrenching i never had a resource like this ive only been here reading a coulple of months and have learned a lot about the 7.3 . and i always think 2 / 3 / or 250 heads are better than one . now im going to dive into the valve covers and change glow plugs / uvch / 50 cent mod / ccv / new boots / i have been pluging my truck in for 7 or 8 years every winter want to see if i can unplug for ever!
thanks wes
Old Dec 15, 2010 | 06:53 AM
Ponyboychris's Avatar
Ponyboychris
Glad you figured it out. The LED's that I found at Radio Shack has a red and a black wire coming from them so it's easy to figure out. And I need all the help I can get.
Old Dec 15, 2010 | 07:51 AM
Mark250's Avatar
Mark250
Glad you got it Wes. Good thing about an LED is you won't burn it up if it's backwards, it just won't work.
bakerbuilttracks
19
Dec 2, 2013 10:08 PM
mikes70gto
May 27, 2010 02:47 AM
Beeler
May 16, 2010 09:39 AM
derekmj64
18
Mar 11, 2008 10:03 AM
