Code 173 and rough idle stalling
Old Feb 24, 2011 | 08:15 PM
  #31
BRay09's Avatar
BRay09
Originally Posted by 90bronco351w
If you have speed density, you will have to have a stock motor(especially a stock cam), otherwise you will have to covert to MAF, which requires a later model computer, change wires around in the harness, and MAF sensor of course. Otherwise you are just wizzin' in the wind. Super tune, chips, etc, results are very limited for speed density systems, and if you have the E4OD transmission it makes it a little harder to convert, because the tranny is controlled by the computer.
This is very untrue... The truck that this thread was meant for is a 96 F250 with Gt40 heads with 1.7RR, stock cam and headers and this system is running on speed density. I forgot to update on this, but i changed the lifters and threw in a new set of OEm 19lb/hr injectors and the thing runs like a top.
As to your comment above, the 89 in my sig has a cam, GT40 heads with 1.7RR and a set of LT headers and she is pushing close to 300hp 350tq running on SD.
Old Feb 24, 2011 | 08:20 PM
  #32
BRay09's Avatar
BRay09
It looks to me like one of the injectors weren't firing at all because the runner in the upper intake was almost clean whereas the others you could see they were being used, like that cyl was really lean. I believe that the injectors were the problem all along because it fires up and runs like i have never seen before. The timing is backed off from before, but when it get a little warmer out here i will bump it back up and see how it handles
Old Feb 24, 2011 | 09:56 PM
  #33
rla2005's Avatar
rla2005
Thanks for the update
Old Feb 25, 2011 | 06:10 PM
  #34
BRay09's Avatar
BRay09
Not a problem. I forgot all about the thread until i got the email of a response. I was happy with the outcome of the injectors and lifters. They (the lifters) were a pain to get out with the heads still on, but it was worth it. Now the motor runs smooth and quietly
NICKSAN
Apr 30, 2017 04:30 PM
frosty95
18
May 13, 2016 09:21 AM
jasmin92993
Aug 17, 2015 08:12 PM
longh2o
Mar 3, 2010 07:34 PM
Boss F150
Jul 5, 2009 09:23 AM
