trans ?
Old Feb 24, 2011 | 07:58 PM
yodavator's Avatar
yodavator
trans ?
i have an 89 f140 4x4 and im tring to figure out what trans i have the truck was rebuilt back in 2003 from a previous owner what do i need to look for to figure it out?
Old Feb 24, 2011 | 08:33 PM
86sixbanger's Avatar
86sixbanger
manual or automatic???
Old Feb 24, 2011 | 08:37 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Is standard, it would be the only M5OD (5 speed) Mazda tranny.
Auto, could be 3 different.
Look on your dash and you'll be able to tell.
P R N D 2 1 = C6
P R N (D) 2 1 = E4OD (will have an overdrive button on the dash, right side of steering column)
P R N (D) D 1 = AOD
Old Feb 25, 2011 | 06:26 PM
yodavator's Avatar
yodavator
ok so i have an aod can i swap with a c6 and if so is it worth it i have 7 inches of lift and sitting on 35's i want something that can handle the wear and tear on and off road
Old Feb 25, 2011 | 06:28 PM
IDIDieselJohn
Yup, you can, but you'll have to find a 4x4 C6 that came off a small block. (300-6cyl, 302 or 351 V8's.)
