79 body switch
Old Dec 13, 2010 | 09:09 AM
tomde2's Avatar
tomde2
79 body switch
hi,
need some info. i got a 1979 f250. i been thinking about getting a 1996( or anything newer)f250 and putting my 79" body on the 96" frame/drivetrain. i got a rotted frame on my79" and i thought the new frame with updated FI motor/trans/transfer case would be nice. i was wondering if anyone has did this.. i dont have access to a newer year truck to take measurements. i tryed to do a search but came up empty.
thanks
Old Dec 13, 2010 | 09:58 AM
cbeer68's Avatar
cbeer68
Replace the 79 parts or leave it alone. The 96 will have an independent front end and plastic gears in the trans and transfer. (JUNK)
What, Ford made real trucks after 1979???
Old Dec 13, 2010 | 11:27 AM
mark a.'s Avatar
mark a.
I would wonder if the wheel wells would be in the right places.
Old Dec 13, 2010 | 11:50 AM
Edgethis's Avatar
Edgethis
I thought the frames were basically the same up to 96. So long as you got the same frame length.
Old Dec 13, 2010 | 02:47 PM
northeaster79's Avatar
northeaster79
they are basically the same,the rad support mounts are different,there is a guy locally here with one,he switched a 2wd body onto a 95 F150 frame.the wheel base is the same 133 (reg cab long box) if thats what you have.There is nothing wrong with the trans/case on the newer trucks.They are not an NP205 but they aren't 30+years old and worn completly out either.and you can get one with the ZF 5spd which is an excellant tranny.I would say go for it if you can get a frame and yours is toast.I know the guy locally who did his swap,I can ask him any questions you need answers for.
s10 warrior
Jul 30, 2012 06:02 PM
79OldBone
Engine Swaps
Jul 16, 2012 10:53 PM
long79crew
Feb 1, 2011 06:32 PM
TheBlueMule
Jul 20, 2008 01:09 PM
79man
Jun 8, 2008 12:57 PM
