Failed State Emissions Inspection !!! Doh!!!
Old Mar 3, 2003 | 07:20 AM
seebeew's Avatar
seebeew
Exclamation Failed State Emissions Inspection !!! Doh!!!
I was told that my O2 sensor was rotted away and that I had an exhaust leak (where the sensor is). I knew of the exhaust leak but figured it was at the manifold.??? The truck passed emissions the last three years with that same exhaust leak. Would a bad O2 sensor be the culprit of my failing? I did a tunup about 12k miles ago and it runs good. Any input??? Thanks
Old Mar 3, 2003 | 07:41 AM
whittey's Avatar
whittey
What part of the test did you fail? A bad O2 should give you lots and lots of HC. When the O2 goes bad (and if the ECU knows its bad), the ECU will pump tons of excess fuel in there to make sure you don't lean it out and blow up. This also absolutely kills your HC's and should drop your mileage.
-=Whittey=-
Old Mar 3, 2003 | 11:45 AM
seebeew's Avatar
seebeew
I failed the Hc and Co I believe.
Old Mar 3, 2003 | 02:44 PM
Ford_Six's Avatar
Ford_Six
HC and CO are very closely linked. High Co readings are caused by incomplete combustion, like running too rich. Likewise, high HC is caused by rich mixtures, but can also be caused by an overly lean mix that causes a lean misfire. In that case, the high CO is actually produced in the cat and exhaust sytem. From what you have said, though, it seems like a rich mix is the problem. But don't take the inspectors advice. Have a shop check it out. Sometimes it is better to pay the $65 for a diagnostic, rather than chase ghosts. And yes, a bad O2s can cause this.
Old Mar 3, 2003 | 10:31 PM
steve83's Avatar
steve83
It's also very important to keep the engine running and hot while you're waiting in line at the test facility. I recently breezed my brother-in-law's '93 Bronco thru inspection. I held it at ~2000RPM while waiting in line (for ~30min ), but it might have passed anyway. I just didn't want to find out.
You shouldn't let them test it within 10 min of starting it. That'll make sure it's fully warmed up AND in closed-loop mode.
Old Mar 4, 2003 | 01:18 AM
tetraruby's Avatar
tetraruby
Don't forget to change the oil too. A fresh change can work wonders for an emissions test.
Old Mar 4, 2003 | 11:41 AM
seebeew's Avatar
seebeew
Here was my results:
My Truck/Legal Limit
HC:
1.95/1.80 gpm
CO:
42.47/40.00 gpm
NOx:
.94/3.50 gpm
Im going to change the o2 sensor and do a light tune up. I hope that does it.
Thanks for the info
Old Mar 5, 2003 | 11:47 AM
seebeew's Avatar
seebeew
I looked at the O2 sensor and the damn thing was hangin and not connected.... I think the ********* at the inspection station wanted to rake me over the coals...I tightened it back up and am going to try another inspection and hope to pass. Just in case, does anyone know how I can reduce those readings (see previous post)? I may want to try a little something easy before I go. Thanks for your help everybody.
Old Mar 5, 2003 | 12:49 PM
whittey's Avatar
whittey
Disconnect your battery for 20min and then connect it again. Drive it normally for a couple days, then go back and run it through again.
-=Whittey=-
KingSuv_01
Apr 22, 2025 02:24 PM
linckeil
Sep 12, 2009 10:40 PM
No_BS
25
Feb 2, 2009 07:39 PM
scroller bill
1978 - 1996 Big Bronco
Nov 30, 2006 08:56 PM
Cobra R
Modular V8 (4.6L, 5.4L)
Oct 6, 2005 03:12 PM
