Cooling a Stroker
Old Dec 10, 2010 | 09:08 PM
grinnergetter's Avatar
grinnergetter
Cooling a Stroker
Well hopefully my engine placement probs are solved which leads me to cooling. I presently have a mild 460 in the truck and have a spare engine which I want to build to a 530 inch engine.
So I'm looking at radiators and the dual fan setup from Flexalite. Got to looking at my core support and it will take a little bit to get it in there. Or get a big block stock radiator.
What do you think $500 or a $1000? Will I need it anyway? I sure don't want to do it twice.
Old Dec 10, 2010 | 10:04 PM
first today's Avatar
first today
Most do the 3g alternator upgrade and install an electric fan from a lincoln mark VIII or thunderbird SC. The fans take something like 90 amps to kick them off, hence the 130 amp alternator upgrade. I am in the process of doing it to my truck now. Seek out member bullitt, he has a nice truck and has made the upgrades.
Old Dec 10, 2010 | 10:38 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I agree, the Lincoln Mark VIII fan is definately the way to go. It's two speed in a single fan that matches the factory radiator profile very well.
Plus, low speed alone pulls 2500-3000 CFM, High speed is 5000+. I dare any to try and achieve that with any aftermarket fan for under $30, let alone $300.
The negative is the fan does indeed need a ton of amps to operate. Mostly during start-up, High speed will easily surge 100 amps from a dead stop.
But, a plus is the ability to retrofit (basically a bolt in) a 3G alternator that cranks out 130 amps and will run just about anything you throw at it.
I have had 7 engines over the years, each one has had various forms of heating problems, but the Mark VIII fan instantly took care of it. And all of it on LOW speed as I have never needed to use High speed to cool the engine. It works that well.
Old dirty picture of the fan installed...
3G alternator...
Shows the low speed and high speed solenoids, triggered with an on-off-on toggle switch.
Thanks for the kind words First Today, appreciate it.
Josh
Old Dec 11, 2010 | 06:37 AM
grinnergetter
What year Lincoln's are you pulling from and is the high-lo switches from the same vehicle?
Got a feeling using the search function would apply here.
Old Dec 11, 2010 | 08:32 AM
first today
I have pulled several lately. They have two bolts to remove them and I try to get as much of the wiring as possible. The thunderbirds are easier to locate. I want to say they are the 97, 98 era. A MarkVIII is a markVIII. I am not sure the year though. I made a shroud for my 460 radiator. I am running a 351 windsor, but plan to use the 460 radiator.
<a href="http://www.flickr.com/photos/love_ford_trucks/4580010922/" title="junkyard 090 by ford collection, on Flickr"><img src="http://farm5.static.flickr.com/4010/4580010922_1fec758522.jpg" width="375" height="500" alt="junkyard 090" /></a>
<a href="http://www.flickr.com/photos/love_ford_trucks/4572522422/" title="junkyard by ford collection, on Flickr"><img src="http://farm5.static.flickr.com/4020/4572522422_9b331e6402.jpg" width="375" height="500" alt="junkyard" /></a>
Old Dec 11, 2010 | 08:41 AM
first today
Try this link to start. There are other ones in this site.
https://www.ford-trucks.com/forums/8...-pictures.html
Old Dec 11, 2010 | 09:50 AM
fordsrgrt's Avatar
fordsrgrt
i have a 521 in my 74 f 250 4x4 and all i use is a super cooler 4 core radiator and no shroud and have no problems keeping it cool in the middle of summer,even with the radiator clogged with mud from the mud boggs
Old Dec 11, 2010 | 01:42 PM
mark a.'s Avatar
mark a.
X2 on the 4 row Super Cooler. If that doesn't cool it then there is something wrong.
Old Dec 11, 2010 | 08:45 PM
grinnergetter
Search yields the B&M trans cooler. Who makes the super cooler?
Old Dec 11, 2010 | 10:42 PM
Bullitt390's Avatar
Bullitt390
It is the "name" Ford called the super heavy duty radiator installed as an option in some trucks.
If I were to get a new radiator I would go with a solid aluminum unit from eBay. Looks great, has good reviews and a great price.
Josh
Old Dec 12, 2010 | 11:30 AM
mark a.'s Avatar
mark a.
I got mine from Performance Radiator, pn 1502. Back in '07 it cost $360.
Old Dec 12, 2010 | 11:36 AM
big78f150's Avatar
big78f150
just to answer the question about what year mark viii, they started making mark viii in 93 to late 90's, possibly early 2000's. i also have a mark VII myself
Old Dec 12, 2010 | 12:14 PM
impalaslayer's Avatar
impalaslayer
i wana say 98 was the last year
Old Dec 12, 2010 | 06:24 PM
SparkyRnD's Avatar
SparkyRnD
here is what I built for mine:
Old Dec 12, 2010 | 06:28 PM
Bullitt390's Avatar
Bullitt390
Yep 1993-98. And that was the end of it, no Mark 9 or Mark X.
Josh
