starting problem
Old Dec 10, 2010 | 01:06 PM
90fourdoor's Avatar
90fourdoor
starting problem
Hi all, I need some help please. I have a 1990 F350 with a 7.3 in it.
Went to <nobr>start</nobr> it the other day and it cranked slow like a dead battery. I went and got the batteries charged and checked, put them back in and it fired up. drove it around for a few miles, came home, turned it off. went back out later and same problem.
took alternator off, had it tested. its good
had starter tested. its good
cables are all good
<nobr>batteries</nobr> are fully charged and good
what else could it be?
Old Dec 10, 2010 | 02:34 PM
michbol's Avatar
michbol
That sounds like contact problems. Go get a battery brush or steel bristled brush. Brush the posts on your batteries and the inside of the terminal clamps until they shine. Get some vaseline and smeer it on the posts. Put the terminal clamps back on and tighten them down really hard so there is no play in them. That should fix it.
Old Dec 10, 2010 | 02:55 PM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/5...ery-drain.html Have a read through the thread in this link and run the checks.
Also good advice from michbol. Make sure the main ground wire is tight where it bolts to the engine, the heavy gauge wire is tight where it bolts to the starter and the connections are tight at the fender mounted starter relay.
Harlakijn
1978 - 1996 Big Bronco
Aug 16, 2013 12:15 AM
bpech69
May 12, 2013 10:33 AM
Powerstrokin7.3L
Oct 10, 2012 07:02 PM
ExcursionBoy1984
Modular V10 (6.8l)
Aug 14, 2012 09:08 PM
Bryishre
Oct 11, 2011 11:55 AM
