battery drain
Old Dec 28, 2006 | 07:58 AM
7.3 idi bandit's Avatar
7.3 idi bandit
battery drain
yet another problem
how do i figure out what could be causin a low voltage drain. if i run the truck daily and un hook the terminals at night there is no problem but if i park it for a day or so th battery is totally dead and i have checked every thing as far as light bulbs and found i believe all of the bare wires but still the bateries go dead
Old Dec 28, 2006 | 08:12 AM
PLC7.3's Avatar
PLC7.3
With the batteries disconnected, place a test light between the pax side disconnected battery cable and the battery. The test light will light, start removing/replacing fuses, any fuse removed that causes the light to go out is the one feeding the offending circuit/accessory. Remember the hood light, glove box, door/interior lights will pe prime culprits...... Feel your alternator on a cold engine if it is warm then there is an internal problem.
Old Dec 28, 2006 | 11:05 PM
FSC's Avatar
FSC
If you have an external regulator and its warm to the touch when it shouldn't be, replace it.
Old Dec 28, 2006 | 11:30 PM
Ben-jamin's Avatar
Ben-jamin
It's going to sound silly but you could have "one' bad battery, you see these batterys are connected parallel so when you unhook them (i'm assuming your doing at the post) you take it out of the loop. even if it just has one weak cell it'll bring the other one down to it's level of charge. hope this helps.
Old Dec 29, 2006 | 07:31 AM
7.3 idi bandit
im sure that the batteries arent bad b/c i put one standard size battery in it and one combine battery ( half again bigger than standard) on the opposite side
Old Dec 29, 2006 | 07:44 AM
Ben-jamin's Avatar
Ben-jamin
and these are fresh batterys?
Old Dec 29, 2006 | 07:48 AM
PLC7.3's Avatar
PLC7.3
Batteries required for our trucks are 2 X 850CCA minimum.......
Old Dec 29, 2006 | 09:16 AM
roamer37's Avatar
roamer37
Both Batterys need to be the same or it will lead to problems like this.. and chargeing problems as well one will not charge at all most of the time
Old Dec 29, 2006 | 08:53 PM
7.3 idi bandit
the batteries are both new and both have the same cca's & ca's one is just bigger than the other also i checked my alternator and the voltage output is between 13.5 and 15.5 depending on rpms also what is the pax side that plc 7.3 is talking about in his reply im a novice when it comes to wiring jargin
Old Jan 5, 2007 | 07:59 PM
sturoe's Avatar
sturoe
this sounds a but elementary but assuming you have the light under your hood that turns on when you open it, that could stay running when its shut. Mine was disconnected when i bought it and I hooked it back up. A couple of days later i figured out why it was diconnected. It had been staying running while the hood was shut. I doubt that would drain your batteries overnight though. Just a thought...
Old Jan 5, 2007 | 08:40 PM
bc6.9's Avatar
bc6.9
Have you done as PCL7.3 has suggested grounding a test light on the batteries? Pulled your fuses 1 by 1??
Old Jan 5, 2007 | 08:43 PM
dieself250's Avatar
dieself250
check and see if your radio is turning off, in one of my trucks the ingition switch is a bit out of adjustment and somtimes when i shut it off and slam the door closed the radio will turn back on
courtneylaw
Jan 14, 2015 11:30 AM
82fordowner
Aug 24, 2014 03:51 PM
DarkWolf40
Electrical Systems/Wiring
Dec 1, 2007 08:51 AM
Railmonkey
2004 - 2008 F150
15
Mar 13, 2006 10:18 AM
