Help installing exhaust needed!
Old Mar 2, 2003 | 08:38 PM
devil421's Avatar
devil421
Question Help installing exhaust needed!
Im installing a Borla exhaust on my 99 Explorer Sport SOHC. Ive gotten the old one removed, except the the part where the flange pipe and clamp pipe (right at the muffler) meet the pipes out of the cat. converter. I cut the hangers and have all the bolts off. The problem is that I cant get the pipes to unjoin (that a word?) where the clamp and flange are. They seem practically fused together. How do you guys get these removed/separated? Im thinking I may have to cut it off but I really don't want to if I dont have to. I used Liquid Wrench and whacked on it with a hammer to loosen....no dice. Any help or suggestions? If I have to cut it off how can I make sure the new system matches up ok?
Thanks!!
Old Mar 3, 2003 | 12:39 PM
reberhardt's Avatar
reberhardt
It will probably take a good beating to get them apart. The connection you are talking about, the pipe slides in to the other pipe. A "U" clamp is then tightened down around it. When I put my Borla on my '97 SOHC a few years ago, my exhaust came apart pretty easily. I live in Arizona though so I don't have to contend with the corrosion that a lot of vehicles are subjected to. If you can't beat it apart then you will probably have to cut it off and then work the left over pieces of metal out of the pipe.
Old May 10, 2007 | 10:51 AM
mcderm99's Avatar
mcderm99
How long ago did you get the Borla cat-back for the explorer sport? They don't seem to offer it now....thanks
Old May 10, 2007 | 01:59 PM
CobraXP's Avatar
CobraXP
Welcome to FTE mcderm99!
This thread is 4 years old, so I imagine you might not get a response. Borla is a site sponsor - you can find their link at the top of the page. I would give them a call and see what they can do for you!
dixiestripes351
1997 - 2003 F150
Apr 14, 2011 05:51 PM
gray91
General Automotive Discussion
Nov 29, 2007 04:35 PM
fordman16b
Oct 26, 2007 09:58 AM
elkarcher
Sep 18, 2007 03:17 PM
bloomy63
Sep 3, 2006 02:45 PM
