Do I have a miss?
Old Dec 7, 2010 | 11:36 AM
6CylBill's Avatar
6CylBill
Do I have a miss?
Howdy folks!
I thought mom's Escape battery was dead so I jumped in the F-150 and cranked her up. It's 20F today, feels like 7. Pretty cold.
After pulling the F-150 back into her stall, I revved it up to 1,100 rpm (holding it there). I couldn't help but notice the very sudden drop in RPM and the truck make a kind of "shudder". Very very brief but this would happen every few moments holding it at this RPM.
Is this a miss?
Thanks everyone!
Truck is a '94 with an I-6.
Old Dec 7, 2010 | 11:48 AM
deeznuts822's Avatar
deeznuts822
I believe you have a stumble, or hesitation. A miss will be somewhat consistant and the motor will shake around
Old Dec 7, 2010 | 04:16 PM
300 Buster's Avatar
300 Buster
Hi Bill,How are ya doin? Before you get too wound up on it,try putting some dry gas in your tank,you may just have a little water.I have run into that before,and on these EFI's it tends to act a little weirder than on the carb engines.It's good insurance for winter anyway,that baby freezes a line on you and you'll be spittin' nails.Hope that's all it is.
Old Dec 7, 2010 | 04:34 PM
lew52's Avatar
lew52
How long sence it had a tune up ?? bad wire or plug will do it.. Lews
Old Dec 7, 2010 | 06:53 PM
6CylBill's Avatar
6CylBill
Thanks guys for the replies! Good to see you Buster and Lew!
Been a while since the truck has had a real tune up.
It seems to only do this at that one spot in my RPM band. What is the difference between a hesitation and a miss?
I'll try the dry gas thing. As cold as it's been, and how the truck has been sitting, I wouldn't be suprised if it was water in the fuel.
Old Dec 7, 2010 | 08:02 PM
court1100f's Avatar
court1100f
A miss depending on severity will be like pulling a plug wire or again depending on how extensive and severe the situation more than one wire and starting it up. a Stumble or hessitations exactly that it kinda falls on it's face with a stumble Hessitation is you giver gas and theres a delay in response or sluggish response
Old Dec 7, 2010 | 10:53 PM
300 Buster's Avatar
300 Buster
Bill, you may have just caught her in a quirk,may not do it all the time.I had my engine light come on going up north then it went away,2wks later it came on again on the way back from up north after filling up at the same station.The code said it was an O2 sensor heater,then it went out and hasn't come on since AND I haven't ever filled up at that station again.So you see,unless it constantly continues,it could be even the gas that happens to be in it right now,or maybe you just pissed her off right then.See what happens for a little while.
Old Dec 8, 2010 | 12:09 PM
6CylBill's Avatar
6CylBill
Thanks Court!!
Mr. Buster, I'll get back to you on that. My truck is very quirky. Sometimes she'll do things for a short bit then go away. I am indeed going to put some dry gas in the tank though, because of how the truck has been sitting and the cold cold cold weather!
Old Dec 8, 2010 | 04:08 PM
court1100f's Avatar
court1100f
no problem bro
Old Dec 9, 2010 | 12:45 PM
6CylBill's Avatar
6CylBill
OKay, I put some dry gas in the tank. Hesitation seemed to subside for the most part, until today. Seems like the truck needs to warm up and stay warm for a good while before the hesitation completely disapears. Note also that until the hesitation is gone my low end power seems to take a noticable hit.
Conclusion: I'm not going to worry about it right now. The truck needs a good going over and a good tune up. I'm sure this is fuel related because of the unrelenting cold weather.
Thanks again friends!
Old Dec 16, 2010 | 04:36 PM
im2tall33's Avatar
im2tall33
hmm maybe test your tps.. also maybe clean out your egr valve my old flareside di the same thing i cleaned the egr and poof it went away
99F-250XLT
23
Apr 1, 2013 07:29 AM
ChunderDownUnder
Jun 10, 2009 04:11 AM
cbjr61
Aug 3, 2005 01:07 PM
quads
Oct 9, 2000 01:59 PM
