Need Help With Diagnosis
Old Mar 29, 2013 | 04:12 PM
99F-250XLT's Avatar
99F-250XLT
Ok, this problem started about three days ago. When I start my truck when it's cold, it fires right up like it always has. Then I back out of the carport and go up the driveway to the road. turn onto the road and proceed up the hill, maybe a 4% grade. Then the truck starts slowing down and missing like it's running out of fuel. I haven't noticed any smoke when it does this. I pull off the road and it dies. Key off and back on prime for a few seconds then try to restart. I always do a key off and back on before I try to restart, and wait for the Wait To Start light to go off. It finally restarts after about 10-12 seconds of cranking and runs real rough, usually dies again in after a few seconds, I have to give it full throttle to get it to restart every time. Most of the time it will idle but when I try to drive off it has no power for a few seconds then takes off fast then runs rough again and dies. I rev it up a few times and it will finally straighten out and run okay.
Here is the data I was able to gather.
IPR Absolute
Idle 466.7-489.9
holding RPM at 1750 890-910
Holding at 3300 1475 then ramps up to 3200 psi
have to keep increasing throttle to maintain rpm when the pressure starts to ramp up. then after it does this I can feel a miss at idle. also when returning to idle the rpm goes down to about 500 and roughens up a little then stabilizes around 750, still with a miss
cylinder contribution shows #4 and #8
Buzz Test
1 ok
2 ok
3 very slightly muted
4 a little more muted than 3
5 ok
6 ok
7 ok
9 ok
8 ok
Any help would be appreciated!!!!
Old Mar 29, 2013 | 04:31 PM
Shake-N-Bake's Avatar
Shake-N-Bake
My suggestion is to find some way to check fuel pressure at idle and under load.
Old Mar 29, 2013 | 07:21 PM
99F-250XLT's Avatar
99F-250XLT
OK. Will do
Old Mar 29, 2013 | 08:44 PM
howellt39's Avatar
howellt39
I thought the same thing, fuel pressure is insufficient. If you don't have a pressure tester yet you can disconnect the inlet side of the frame mounted pump (just under the driver's seat under the truck) and blow some compressed air back into the tank, backflushing the pickup boot screen. If there's an in-tank restriction that should free it and only takes a couple minutes.
Take your fuel cap off to do this.
Old Mar 29, 2013 | 09:01 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Check your ICP reading and ICP sensor for oil. Also, it could still be the IPR. Mine was reading fine but would cause similar problems. However, I agree, check fuel pressure first.
Old Mar 29, 2013 | 09:09 PM
carltonwebb's Avatar
carltonwebb
Have you checked your engine oil level lately?
Old Mar 29, 2013 | 09:14 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Also, check your valve cover harness for burn pins on the connector to the gasket
Old Mar 29, 2013 | 09:43 PM
Mowing Man's Avatar
Mowing Man
I had the same exact problem when I bought my first 7.3 diesel. Changed my fuel pump, checked my tank, etc. turned out my rotten oil pan was leaking faster than I thought. Oil level and quality are critical to these injectors and lack of either will give you low fuel pressure symptoms. I know from trial and error
Old Mar 29, 2013 | 11:42 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
These are the screens you are clearing when you blow compressed air back into the tank.
Don't use anything over 20 psi or so to blow air back into the tank.
Here is what a broken pickup foot assembly looks like inside your tank.
This will cause you to run out of fuel before you are actually empty, and it can cause air in the system.
IPR nut is something that is SOOOOOOO easy to check and rule out. Trey is right on that suggestion.
Old Mar 30, 2013 | 12:14 AM
99F-250XLT's Avatar
99F-250XLT
Your comments about the mixing chamber in the tank are invalid. I did the hutch mod already. Thanks
Old Mar 30, 2013 | 12:17 AM
99F-250XLT's Avatar
99F-250XLT
Should have mentioned also that once it's warm all is good except the miss after revving the engine. It has to have at least a 4 hour soak to act up. Also the ICP sensor does have oil in the connector but has been that way for awhile. The main problem started about 3 days ago.
Old Mar 30, 2013 | 12:30 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Update/establish a signature that is attached to your posts. Put your truck's vital statistics in there so we can better answer your questions/offer help. Things like already having the hutch mod are not known unless you tell us in the original question or make a signature where it is offered as info.
Welcome to the site by the way!
Old Mar 30, 2013 | 12:32 AM
99F-250XLT's Avatar
99F-250XLT
Thanks, will do!!!
Old Mar 30, 2013 | 12:39 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I think you may need to rebuild/clean your IPR. The fact that it does it when cold and then goes away when warm point toward a possible oil temp/viscosity issue. The IPR does develop a build up inside the very small clearances inside it. This buildup needs to be removed periodically. Takes me about 10 minutes to get my IPR out and 10 to get it back in. Taking it apart and cleaning it takes about 30 mins. Although I did put the tiny needle in backwards the last time I did it
Definitely need to know what fuel pressure is as well, though. It's easier to check on the IPR than it is to come up with money for a gauge
Old Mar 30, 2013 | 02:20 AM
99F-250XLT's Avatar
99F-250XLT
Yeah, I saw that on your weekend project thread, Lol
I'm going to go try that in just a few minutes
