Kodiak, If you ever look at the installation instructions for the key fob remote start, you will see that the RF antenna for the remote start plugs into the TPMS module.
You're a few years late to the party Larry! As you saw in my post, I figured out they shared the same receiver. Where were you a few years ago?
Should not have affected the remote start....not sure what you issue is Dave....the two systems are not even closely related....did you check the cluster to see if remote start got turned off for some reason while at dealer?
Kodiak.....naw....not changing brands....i bleed Dark Ford Blue....sold the 5th wheel and then sold the truck....going to look at a gas burner 35' Class A on a Ford chassis....and buddy has a 97 ranger that might buy if he does a little work on it so I have a pickup handy....
All good info here.
Did some testing for a better understanding of some of the points made, drivers door open, RS worked, all doors open, RS worked, hood popped but not open, RS worked, hood fully open, doors open RS worked, doors closed / hood open RS did NOT work
All good info here.
Sounds exactly how mine acted, and I deduced the receiver wasn’t working up to par. New receiver, and everything worked whether the doors are open or not. I used to have my doors all open to retrain the TPMS sensors each time I changes our summer and winter wheels in the Spring and Winter.
I just bought my first truck yesterday, 2017 f350. The listing from the dealership shows the truck was purchased new with a remote starter. But pressing the button twice on the 5-button keyfob does nothing — not even the double horn that it did’nt start. I looked through the menus for something about it to enable, but found nothing. So how can I tell if the truck is even equipped with remote start like the dealer printout says it should?
Or if it automatically comes with remote start fo4 all trucks having the 5-button keyfob, then how do I enable it?
Mark
Mark, the stock key fob has the "instructions" on the back. For the 2015 it was press the lock button and then press the start button twice. Have you checked your owner's manual?
Ah ha! I wasn’t pressing the lock button first (because it was already licked). I don’t remember seeing that in the manual, but it works great now! Thanks!
mark
