Since this is on raditors again and again and,,,,, again there is a guy on another form that had his raritor go bad he said his dealer said Ford would cover 2/3 od the cost of a replacement. Does Ford ever ever cover part of the cost of this type of repair? THANKS
I guess I should have phrased the question more carefully
I am looking for a All metal radiator for my 08,
I have talked to my Dealer.... looks like a ROM of $1000 to have it replaced with the same design...... isn't this the definition of insanity???? doing the same thing over and over and expecting different results???
I have not heard of any all metal radiator for the 08-10 6.4 family.
But this seems to be a byproduct of the REAL problem, the thermostats sticking, and causing way too much pressure. this also means the water pump bypass isn't big enough
