Changing Fuel Filter
Old 12-05-2010, 09:43 AM
regidog's Avatar
regidog
regidog is offline
My fuel filter light has been coming on intermittently during hard acceleration. I figure it is a combination of the colder weather thickening the fueld and the filter needing to be changer. I have read you need to prime the filter with diesel or additive, and some have posted about bleeding the schrager valve, I am a bit confused as to what needs to be done. Can someone post a quick procedure for changing the fuel filter in a 1992 IDI? Thanks in advance.
Old 12-05-2010, 10:18 AM
Marshall91F250's Avatar
Marshall91F250
Marshall91F250 is offline
Ford diesel 6.9 7.3 IDI
A warm engine helps getting it started after changing it. Put some oil around the gasket like you do with oil filter. fill it with your favorite diesel additive and your ready to install.
Old 12-05-2010, 10:41 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
crank 15 seconds max/let the starter cool 2 min.then crank again.
have a battery charger handy in case you need it.
don't burn up your starter.
Old 12-05-2010, 11:07 AM
regidog's Avatar
regidog
regidog is offline
Sounds like I just: 1) warm up the engine 2) spin loose the old filter, 3) fill the new one with additive (diesel kleen in my case), 4) Put some oil on the seal, 5) spin on the new filter, 6) crank her over for no more than 15 seconds. Seems easy enough. Thought there was more to it. Thanks
Old 12-05-2010, 11:22 AM
tlk50's Avatar
tlk50
tlk50 is offline
I think what he meant was:
Warm the engine up, shut it down, install the new filter as stated (I prime with Diesel Kleen also) start it up (don't burn up the starter) and let it run for 10-15 seconds then shut it down for 30 minutes to an hour. Letting it set for awhile gives the Diesel Kleen a chance to remove varnish from your system. Then fire it up and you should be good to go.
Old 12-05-2010, 11:24 AM
FORDF250HDXLT
thats it.
the cranking spins the mechanical fuel pump,which pumps fuel up through the lines again.it has to press out some air too.
that's why all the extra cranking,to re prime the system again.
pretty much everything to do with this engine is quite basic.
sounds easy enough,though it can be a real hair puller lol,so have the battery charger ready.
Old 12-05-2010, 11:27 AM
FORDF250HDXLT
Warm the engine up, shut it down, install the new filter as stated (I prime with Diesel Kleen also) start it up and let it run for 10-15 seconds then shut it down for 30 minutes to an hour. Letting it set for awhile gives the Diesel Kleen a chance to remove varnish from your system. Then fire it up and you should be good to go.
actually,
warm the engine right up to operating temp.
(drive her for a good 20 minutes,or do this just after a trip home from work etc.)
swap the filter inside just 10-20 minutes (as soon as possible.)
this way,when you go to restart with an empty fuel system,your not fighting a cold start and a losss of prime start at the same time see?
with a good glow plug system,that's not going to make a whole lot of difference.the re-prime is what can give ya hell lol.
Old 12-05-2010, 11:30 AM
tlk50's Avatar
tlk50
tlk50 is offline
Oh, I forgot, make sure the new filter is as full as possible when putting it on. I always lay a rag over the valve cover to catch the spillage.
Old 12-05-2010, 11:39 AM
Country_boy_2007's Avatar
Country_boy_2007
Country_boy_2007 is offline
you may need to crack the fuel line going to the ip too blead air to, but you should usually be able to get it started.
Old 12-05-2010, 02:55 PM
regidog's Avatar
regidog
regidog is offline
All done, worked like a charm.
Filled up the filter plus a little with Diesel Kleen, screwed here on, turned the key and fired right up. Let her run 15 seconds and turned her off for 20 minutes or so, fired her back up and let her run a half hour. Not a hessitation, and appears to run a little smoother. Thanks fellas. Made my first diesel fuel filter change a breeze!!
Macs1964F100
13
06-25-2014 07:50 PM
Trigger johansen
04-13-2011 03:59 PM
AlbyVA
6.4L Power Stroke Diesel
15
08-19-2010 05:23 AM
fastg60
15
06-20-2006 01:29 PM
1Knight
12-23-2005 03:41 AM
Quick Reply: Changing Fuel Filter
