how long would it take you to swap a break caliper in a time pinch?
Long story short my dad leaves with "Thumper" early tomorrow for St. Joe and my front driver side caliper is bad... He needs to do a kitchen install all weekend down there and will need all the time he can get... He already has the truck, and said he could swing by early tomorrow if i can fix it quick enough and get him back on the road... So...
How quick could you change the caliper out and rebleed the line??? Keep in mind i have an impact and all the tools i could possibly need...
It's just pulling the wheel, a couple caliper bolts and disconnecting the break line right??? Or am i missing a step? no special tools needed right???
......if all goes well though, 30 or less.
Received 5,160 Likes
on
30 Min max from tire off to tire on (I've done it on my F250 and my old 90 Bronco), also, DO NOT go and clamp the rubber brake line off with a set of vise grips unless you want to end up replacing the hose later (if not right then when the grips tear up the hose). Either use a true set of hose clamps, or have your someone just hold their fingers over the hose end to keep it from dripping too much. Even without sealing the hose end you won't lose much fluid from the time you take it off the old caliper until you bolt it to the new caliper
Normally I do this, I pop old caliper off mount and set it up on spring or zip tie it off some place, mount new caliper with pads on truck, make sure master cylinder is topped off, then remove to banjo bolt from the old one letting the hose hang and drip in catch pan, pop the old copper washer off the bolt, replace top copper washer, insert in flex hose, attach bottom copper washer, thread in to hole, tighten up, check fluid level and top if needed, open bleeder and let it gravity bleed out, dripping in to catch pan ( some times I'll put a hose on bleeder ), Once fluid comes out of bleeder, I'll close and have someone peddle bleed it 2 or 3 times to be sure the air it out.
annaleigh
15
11-11-2015 10:34 PM
SOLOLUCKY
08-14-2013 08:59 AM
CobraGT40
03-19-2010 07:24 PM
