Ignition key cylinder no key???
I have looked through threads trying to find what i need but cant find it. What im having a problem with is someone lost the keys to my truck, its been sitting for years now, anyways i need to drill out the cylinder and replace with a new one?????? I am mechanically and electrical inclined but this is something i havent had to do before lol. from what i gather its more or less drill center out with 3/8" drill bit and use paper clip in small hole to remove??????? I can get a new cylinder at autozone for $5.99.....
I've never replaced one so that may be the case, but I'm willing to bet that your local locksmith could help you out there too. It's an extremely un-complicated mechanism, I bet you could "pick" the lock and turn it without damaging it.
Our local locksmith has a mobil unit that will come on site. It may cost more than $5.99, but it would probably be far less likely to damage something. Might be worth making a few phone calls first.
For the dash mounted ignition cylinders, you just need to unplug, unscrew the bezel ring and it'll come right off.
Apparently. There is a reason why old vehicles were so much easier to work on. It's because they were made to be easier to work on! Granted they were also easier to steal.
It's been a while since I tried to remove the cylinder fron the switch itself.
yeah samick i went and did that, got them seperate but for some reason i cant get the cylinder lined up in the switch right for it to lock in....... i got it deep enough to lock in once but then key wouldnt move..... things like this drive me nuts......
I kind of had a similar sounding issue. There is a pin hole in the face of the cylinder, that you'll need to insert a pin, nail, screwdriver, or whatever in to, so you can turn the lock past where that pin makes it stop normally. Once you do that, you should be able to slide it all the way in. They used to provide the pin to do that, but they don't anymore. Not that I've seen anyways. Good luck!
akg123
Dec 14, 2015 03:36 PM
fordtrck302
17
Dec 6, 2015 05:21 PM
GuitarJesus
Oct 14, 2015 09:02 AM
Larry Wall
Feb 6, 2015 08:48 AM
