1999 ignition wire 4 volts with key in off
I have a 1999 expi that has become troublesome. It will not turn over, or crank if you will. I believe it is the solenoid, but when I was checking voltage to it I was seeing something that did not make sense to me. With the ignition off I read 4 volts. If I shift it out of park or neutral then it reads 0 volts. When I turn the ignition to start while in P or N then I get 12 volts, and 0 if in another gear as expected. This tells me the neutral safety switch is working.
What I am not sure about is why I am getting 4 volts with the key off.
By the "S" wire, are you refering to the tan wire (that comes from the DTR sensor) that pulls in the starter motor RELAY up on the firewall?
Or are you refering to the red wire (that comes from the starter motor relay) that is connected to the "S" terminal on the starter motor SOLENOID down on the starter motor?
And is the wire connected or disconnected when you take your meter readings?
And what postion is the ignition switch in when you are taking each reading?
What projectSHO89 said, but if you are seeing some voltage (with fuse #20 AND #21 pulled) on that tan wire while it is connected to the relay a bad relay may be leaking voltage into the relay's coil.
In any event, it's a curiosity unrelated to his actual starting problem.
Matt Kioski
06-30-2015 12:39 AM
Manimaul
08-13-2005 10:39 PM
torquemeister
03-12-2003 12:55 PM
